Old 10-16-2011, 01:23 PM   #1
Boyd's Avatar
Battery Equalization charge question
The following statement was pulled from the interweb. My question is, "Will the movement/driving of the RV act as a "mixer" of electrolyte in the coach's, flooded deep cell batteries or is an equalizing charge absolutely essential for extended battery life?"
"Flooded battery life can be extended if an equalizing charge is applied every 10 to 40 days. This is a charge that is about 10% higher than normal full charge voltage, and is applied for about 2 to 16 hours. This makes sure that all the cells are equally charged, and the gas bubbles mix the electrolyte. If the liquid in standard wet cells is not mixed, the electrolyte becomes "stratified". You can have very strong solution at the bottom, and very weak at the top of the cell. With stratification, you can test a battery with a hydrometer and get readings that are quite a ways off."
Thanks in advance
"If everything seems to be going well, look around, you've obviously overlooked something."
Boyd is offline   Reply With Quote
Old 10-16-2011, 04:25 PM   #2
Triguy's Avatar
Just throwing this out here, as I am not well-versed on equalization, but I am not sure about the 10-40 days part. At least with Trojan batteries.
When I read my manual from Trojan, they say its based on its specific gravity after a full charge or if there is a big difference between cells (as I understand it).
Name:	Equalization of Trojan batteries.GIF
Scott
DW, 3 Kids and our Goldens
2012 Shamrock 233S
2008 Toyota Sequoia 5.7L 4WD
battery
