Old 05-14-2018, 06:50 PM   #1
Battery getting hot
Have a 2006 Rockwood TT. The battery gets hot as soon as you hook it up. It only happens when the shore power is hooked up as well. I switched out batteries, checked all fuses and GFCI's. Everything is working fine inside. Any idea of what it could be - maybe the converter?
mjknight02 is offline   Reply With Quote
Old 05-14-2018, 06:51 PM   #2
WolfWhistle's Avatar
If its a flood type check the fluid level, sounds like a case of dry cells. If not the case, it sounds like a serious case of overcharging
WW
Hyper Lite was sold
2017 F-250 4x4 6.2L Gas
Old 05-14-2018, 06:52 PM   #3
Flybob's Avatar
Battery is bad. You probably have a shorted cell. When connected to shore power the convertor is trying to charge it so it will heat up and can boil out all the water if it hasn't done that already, Replace the battery you will be fine.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 05-14-2018, 09:13 PM   #4
Too much voltage to the battery (>14.5 volts) or whatever is charging the battery (converter) is overcharging the battery. Bad converter?
briteday is offline   Reply With Quote
Old 05-15-2018, 07:43 AM   #5
My absorb point is set to 14.8v (2 - 6 volt in series - actually have 2 sets) and is what's recommended by the manufacturer. Now if it kept that up all day, or more, I would agree. This is easily tested. I actually equalize at 16.2v (each pair) when needed - every month or so based on SG readings taken. My batteries are now 3 years old and close to new in performance. But, I keep them clean and full.
WW
Hyper Lite was sold
Old 05-20-2018, 08:07 PM   #6
The batteries weren't the issue so I ended up installing a new convertor. That took care of the battery getting hot but now I don't have any DC power inside. I only have DC power to the tongue. Even with shore power is plugged in, there's no continuity. i checked everything I can think of. Any ideas? Thanks!
Old 05-20-2018, 08:20 PM   #7
Flybob's Avatar
Check reverse polarity fuses and the resettable breaker under the tongue. See Photo.
TST Tire Monitors
2 100W solar panels
Old 05-20-2018, 08:21 PM   #8
cavie's Avatar
check the 2- 40 amp fuses on the converter.
2002 27rk Wildcat 5er.
Port Charlotte Fl/Hinsdale Ma
Retired Master Electrician.
battery
