Old 04-21-2013, 05:27 AM   #1
battery hook up
I have a 2013 flagstaff 831 rlbss the battery cables are red with a strip of black tape on it the other is all black is the positive the one with the black tape also is it alright to connect 2 30amp extension cords together and how to you need water out between the plugs
steve831 is offline   Reply With Quote
Old 04-21-2013, 05:45 AM   #2
My (Pos-+) cable is Red. Didn't you have a Batt. hooked up when you left the Dealer? For a Temp cover on the (30A) plugs I use a 2 liter plastic bottle,slit to fit. Youroo!!
Old 04-21-2013, 06:04 AM   #3
I got the trailer in september and took the battery out for winter nows its time to put it back in
Old 04-21-2013, 06:17 AM   #4
Steve & Phyllis
SteveBingham52's Avatar
If you have even the slightest doubt it is much safer to just swing by a dealer and let them take a quick look. Shouldn't take them but a minute and probably wouldn't charge you. DO NOT guess. You can do some pretty expensive damage if you guess wrong.
SteveBingham52 is offline   Reply With Quote
Old 04-21-2013, 06:26 AM   #5
Don't swing by with your trailer,without the Batt hooked up,(No Brakes)! Youroo!!
Old 04-21-2013, 06:32 AM   #6
Wildcat661's Avatar
Follow the cable
See if you can follow the battery cables. The cable that is bolted to the trailer frame would be your negative one. Did mine yesterday just to make sure.
Wildcat661 is offline   Reply With Quote
Old 04-21-2013, 06:37 AM   #7
crunchman12001's Avatar
X2
2015 F-250 FX4
Old 04-21-2013, 09:21 AM   #8
Stop by the dealer without the trailer and ask.
2012 Palomino Ultralite T245
2004 F250 Supercab 5.4L
09 Grizzly 700 EPS
09grizzly1 is offline   Reply With Quote
Old 04-21-2013, 09:33 AM   #9
harleyguy's Avatar
I did the same thing with my coachman battery and emailed coachman. But the quickest solution would be to call the dealer
harleyguy is offline   Reply With Quote
Old 04-21-2013, 09:38 AM   #10
mshell56118's Avatar
If you have a multimeter you could put one lead on frame where there is some bare metal and then check the two cables with meter set to ohms the one that reads almost zero would be your ground cable ( negative)
mshell56118 is offline   Reply With Quote
Old 04-21-2013, 09:43 AM   #11
Only no emergency (break away brakes) brakes. Normal brakes powered from TV
Of all the things I've lost in my life the thing I miss the most is my mind!
prairiecamper is offline   Reply With Quote
Old 04-21-2013, 09:44 AM   #12
Road-King's Avatar
X1
Russ & Kim
2014 Alpine 3600RS
2007 Dodge Ram 3500 5.9 4X4
2008 Harley Davidson Road King 105th Anniversary
(2011-5 bad year)(2012-40)(2013-45)(2014-23)
Road-King is offline   Reply With Quote
Old 04-21-2013, 01:02 PM   #13
bikendan's Avatar
NEVER go by cable color.
as the others have said, the easiest way is to find which cable is bolted to the frame. that's the negative.
