Originally Posted by texaspete1
I will try that. What does the converter look like. I know where the inverter is.
You don't have to touch the converter to run the tests suggested. In fact, you should not touch the converter since it is hot (AC powered) and has high shock potential.
I would recommend to start with the basics and take it from there. First see if the converter is charging your battery or batteries as suggested above.
