Old 06-23-2015, 03:58 AM   #1
battery installation
1992 sierra by cobra 30f travel trailer with the series 6300a model number 6345 panels with option cn19,(whatever that means) charger and converter. bassically i need battery installation help needed what wires connect to what side of the battery i have never had to connect the battery's to charge them or even use them so now im curious there are 4 wires where they "hookup" which goes to which
alafond07 is offline   Reply With Quote
Old 06-23-2015, 05:31 AM   #2
crunchman12001's Avatar
Can you take a picture of the wires you have? One of the battery gurus will be able to help you connect it properly.
crunchman
2015 F-250 FX4
Old 06-23-2015, 05:55 AM   #3
We need to see the wiring, or a good description of the colors and tentatively where the wires are headed. Follow them back to the frame. Your positive cable will lead to a block fuse located near the batteries. Your ground (negative), will (more than likely) lead to a grounding point directly on the frame of your TT. From there.. more information is needed.
rana is offline   Reply With Quote
battery
