Old 07-27-2015, 10:42 AM   #1
Battery is not charging
2015 Model Sandpiper 376bhok the battery just drains where is the converter on this unit? does it have a fuse?
Joseph96 is offline   Reply With Quote
Old 07-27-2015, 10:56 AM   #2
Need more information on the problem. Is it plugged in and not charging?
2016 Flagstaff 23lb
Toddupton is offline   Reply With Quote
Old 07-27-2015, 10:57 AM   #3
TURBS's Avatar
Converter is in or behind the electrical distribution panel.
Most likely it's a wfco converter and you need to check out the files section on this forum and look @ the wfco troubleshooting guide.
TURBS
08 duramax tuned n modded
2011 32bhok Sabre
2015 camping "15 nights"
Old 07-27-2015, 11:25 AM   #4
Yes a Search will give you (Step by Step) for WFCO check! ^ Youroo!!
youroo is online now   Reply With Quote
Old 07-27-2015, 01:24 PM   #5
There will be a circuit breaker in the panel for the converter. Check it first.
Harkerr is offline   Reply With Quote
Old 07-27-2015, 07:25 PM   #6
ervinglobal's Avatar
Do you have a battery disconnect switch? Might be off. I did that ones.
ervinglobal is offline   Reply With Quote
Old 07-27-2015, 07:42 PM   #7
Our TT has a fuse at the first junction box from the 7-pin plug/cable. I know that the battery won't charge if that is blown. Different model than yours but doesn't hurt to look.
2015 Viking 17FQ TV: 2005 Lexus GX470
bbrowncods is offline   Reply With Quote
battery, charging
