Old 02-02-2014, 06:56 PM   #1
Battery issue
I have a 2006 cardinal and have changed batterie so i have new one but still goes dead after couple of days any ideas?
jbroussard55 is offline   Reply With Quote
Old 02-02-2014, 07:15 PM   #2
bikendan's Avatar
does this happen when the trailer is plugged into shore power or when it's NOT plugged into shore power?
and does your trailer have a battery disconnect switch?
if it's not plugged in and you don't have a disconnect switch, then the trailer's normal parasitic power drains are the probable cause. especially if you have a single battery.
you'll have to keep it plugged in or get a disconnect switch installed.
Dan-Retired Firefighter/EMT
Equalizer WDH and Prodigy BC
Old 02-02-2014, 07:24 PM   #3
It happens when plugged and un plugged.I've had the rv for about a year and this just started happening.i do only have 1 batterie
Old 02-02-2014, 07:25 PM   #4
Also i do not see disconnect switch for batterie
Old 02-02-2014, 07:51 PM   #5
bikendan's Avatar
then first thing would be to test the converter.
Old 02-02-2014, 08:06 PM   #6
How do i do that?
Old 02-02-2014, 08:18 PM   #7
I checked hot hot cable (red) that is connected to batterie and no juice.
Old 02-02-2014, 09:26 PM   #8
sherdep's Avatar
sounds like you may have a bad fuse in the load center
verify your fuses are good
or
there should be a automatic resettable fuse block somewhere close to the battery - may have to trace the hot (red) from the battery back to along the frame and check it on the block
2011 Rockwood Mini Lite 2306 - Matt
2004 Dodge Ram 1500 Qaud Cab 4x4 with 35" tires and 3.92 gears, Dynatech Longtube Headers & Fabtech 6" lift + Superchips with shift Tuning
Nights Camped 2011 (37) - 2012 (16)-2013 (2) -2014 (5) -2015(0)
USMC 91 - 95 - F/A-18 Aviation Ordnance
sherdep is offline   Reply With Quote
Old 02-03-2014, 09:45 AM   #9
Herk7769's Avatar
There are two resettable current limiters between the converter and the battery "red" cable.
Look within 18 inches of the battery for one, and somewhere on the frame (or under the pin box on a 5th wheel) for the other.
Check for corrosion and a popped reset button on the side.
ID:	45755   Click image for larger version
Name:	Camper Photos 003.jpg
ID:	45757   Click image for larger version
HAM CALLSIGN - KC3FFW
Old 02-03-2014, 10:21 AM   #10
I had this problem a few years ago and it was my converter. It happened while on vacatin. I now carry a spare.
OKI Marine is offline   Reply With Quote
