Old 09-29-2013, 12:45 PM   #1
raspivey's Avatar
Battery Monitor Panel Accuracy
Just a quick question:
How accurate are the level indicators on the stock panels? For instance, when the panel indicates 50% or 75% battery, roughly what voltage should the batteries be at?
I'll find out for sure in a few weeks when I dry camp for the first time in this trailer, but I was just curious if anyone knew off the top of their head. My last trailer didn't have an indicator and I just used a multimeter to watch them. Until I get around to installing a panel inside, that's what I'll still do. I'm hoping that it's scaled to around 12.2V at empty. I wouldn't even start to check them until 50% if that were the case.
Old 09-29-2013, 01:24 PM   #2
Iwannacamp's Avatar
My old battery days... A battery(lead acid) is supposed to be fully charged at 12.6v. This also has to do with specific gravity. My assumption is if it's "normal" then it would be charged. A 12v reading should be 50%
2017 Puma 297RLSS
2005 Ram 2500 4X4 diesel
Our new 5er 10-26-16
Old 09-29-2013, 01:37 PM   #3
raspivey's Avatar
I just re-read my post. Mine generally read about 12.9-ish when fully charged. I never run them below 12.3V as 12.2 is around 50% charged most of the time. What I was really curious about was, for instance, if the lights on my panel inside show 50%...is that about 12.2V, or are they scaled differently? Like I said, I'll find out for sure (at least on my unit) in a few weeks. I figured somebody here would have experimented a little.
Old 09-29-2013, 01:39 PM   #4
See picture:
Old 09-30-2013, 08:13 AM   #5
Herk7769's Avatar
Originally Posted by BarryD0706 View Post
See picture:
Attachment 40421
I have this exact graphic next to my TM-2025 battery monitor!
HAM CALLSIGN - KC3FFW
Old 09-30-2013, 08:21 AM   #6
So let's ask the same question of you that the OP is asking for the cheapie monitors: Does your "% Full" read relative to 50%-SOC or relative to 0%-SOC?
Old 09-30-2013, 08:31 AM   #7
Herk7769's Avatar
That one is easy! It is in the monitor manual. Look to the right on the graphic of a typical panel. the lights to not read like the tanks.
They read "C", "G", "F", and "L"
All four lights mean: CHARGING - Voltage above the fully charged voltage
three lights mean: GOOD - Voltage above 50% discharged - use ok
TWO lights means FAIR - VOLTAGE VERY LOW (less than 50%) - MUST BE RECHARGED to avoid battery damage.
ONE light means LOW Voltage above 6 volts (enough to power the light) and damage IS occurring.
NO LIGHTS - Battery removed or too dead to recharge.
Name:	Battery Display.jpg
ID:	40446   Click image for larger version
Name:	Charge Chart.jpg
ID:	40447   Click image for larger version
Old 09-30-2013, 09:12 AM   #8
raspivey's Avatar
I wasn't very clear about this but, yes, this is exactly what I was getting at.
I don't have a stand alone panel...it's integrated into the switch panel and shares lights with the tank levels. All that's marked on it are E, 1/3, 2/3, and F ( I think...I'll go check in a little while). I'm double checking all of my manuals, but I don't remember ever seeing one for the panel.
I always meant to put a Trimetric unit on my last trailer and never got around to it. It's definitely on the list for this one, just probably not until after the first of the year.
Old 09-30-2013, 10:27 PM   #9
Herk7769's Avatar
I think you will find the battery legend is as I described.
However if it is not so marked, I would assume the lights still represent the voltage values I listed.
Old 09-30-2013, 10:33 PM   #10
raspivey's Avatar
It is...I finally managed to go look at it. From the experience I have with 12V, that panel is completely useless to me. Full may not be full and good, well....isn't. Once it comes off of full it could be anywhere between 50 - 90%. Kind of defeats the purpose. I may just go ahead and order a 2025 tonight, it'll beat the constant multimeter checking (I'm kind of paranoid with my batteries).
battery
