Old 05-29-2015, 11:27 AM   #1
Battery Monitoring Gauge - Trimetric
Hello Forum,
I have a 2011 Sunseeker 3010DS and I have recently installed a Trimetric 2025 battery monitor. I am getting voltage readings from the meter that are fairly accurate. However, I am not receiving any amp readings. Has anyone installed such a device or similar device and gotten it to work properly? Is there a wiring diagram that would show which wires go where inside the RV? I am running the meter partially thru the battery cutoff switch so it isn't always on, I don't know if this is right.
any assistance would be very helpful.
regards,
bfrtech
bfrtech is offline   Reply With Quote
Old 05-29-2015, 12:01 PM   #2
rsscully's Avatar
Did you install a shunt?
rsscully is offline   Reply With Quote
Old 05-29-2015, 12:05 PM   #3
rsscully's Avatar
Amp Ammeter DC 300A 75mV Current Measure Shunt Resistor https://www.amazon.com/dp/B006Z954QA..._NWjAvb0ZDWH1G
Old 05-29-2015, 12:07 PM   #4
yes it is running thru a shunt. I have an extended negative going to one side of the shunt and the other side is running off of the battery cutoff switch. I think that it has something to do with my Power Distribution Module.
thanks,
bfrtech
Old 05-29-2015, 12:10 PM   #5
Actually, you want your shunt to be upstream of any other connection and as near to the battery lead as possible. You can attach light loads directly to the downstream side of your shunt, but nothing between the shunt and terminal.
rana is offline   Reply With Quote
Old 05-29-2015, 12:45 PM   #6
This diagram shows how they say to install it. I have the negative from my two house batteries going to the left side of the shunt. Onto the right side of the shunt, I have a wire going from my battery cutoff switch.
It seems as if all of my DC power goes thru my PDM and then to the switch, would this make sense?
Thanks.
Old 05-29-2015, 12:56 PM   #7
Yep. Sorry. I guess I got confused when you said "from" the switch rather than "to". Instead of battery > shunt > switch it sounded like battery > switch > shunt.
You're good
Old 05-30-2015, 11:40 AM   #8
I believe every time power is dis-connected you have to re-program the initial data.
Of all the things I've lost in my life the thing I miss the most is my mind!
prairiecamper is offline   Reply With Quote
Old 05-30-2015, 08:01 PM   #9
Herk7769's Avatar
I believe the data you program is held in an ePROM. It keeps data permanently unless changed or erased. My TriMetric retains last recorded data even with the batteries disconnected.
This can be a problem if you remove the batteries and charge them up where the shunt can't measure the charge you put in while it is out of the system.
If you are sure the batteries are full; just reset the percent discharged to 100% by selecting that and holding the reset button for 3 seconds or so.
HAM CALLSIGN - KC3FFW
Old 05-30-2015, 08:05 PM   #10
Herk7769's Avatar
Here is how mine is installed:
Just make sure your solar charge controller has a blocking diode in the output and put the battery switch to both to solar charge.
Name:	My wiring diagram.jpg
ID:	78565   Click image for larger version
battery
