Originally Posted by A32Deuce
My understanding on cutting off Go power solar is to cover the panels. That's what my instructions said, not a cutoff from the panel feed. This was back in 2012, it may have changed.
If one wants to cut off solar I believe the recommended method (other than covering) is to install a switch between panels and controller.
Since I use portable panels I just unplug.
If one has a permanently mounted panel array then leave them on and let the solar controller maintain the batteries.
A note, don't forget to check water if lead acid batteries. Also, lithium battery mfr's recommend against leaving their batteries on a float charge for extended periods of time. Once they are fully charged the charger should be shut off so a switch is in order between panel(s) and controller.
2023 f-150 SCREW XLT 3.5 Ecoboost (The result of a $68,000 oil change
