Old 01-11-2017, 09:25 AM   #21
Insert witty title here
Is it a flooded battery. Have you ever checked the acid levels inside?
2021 Transcend Xplor 247BH
Husky WDH with Sway Control
2021 Chevy Silverado 2500HD LT 6.6L V8 Duramax
Forever in my memory. Forever in my heart.
Laurie J. Wood 3/22/67 - 8/23/19
timfromma is offline   Reply With Quote
Old 01-11-2017, 09:57 AM   #22
Flybob's Avatar
It will take a while (overnight) to charge the battery so what you are seeing now sounds right. You should see about 13.8V on the battery while it is charging. I would leave it over night. Then unplug from shore power and wait a few hours and test the battery again. should be between 13.6 and 12.6. There is no issue testing the battery or playing with it in the rain other than you getting wet.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 01-11-2017, 11:49 AM   #23
thestrangebrew's Avatar
Thanks Bob. Checked this morning and I have 3/4 charge so it's working now. I thought I had a multi-meter but it's just a voltmeter so I'll pick up a multi-meter and read up on how to use it to test things. Thanks all for the help!
2022 F250
2014 Rockwood Roo 233s
thestrangebrew is offline   Reply With Quote
Old 01-11-2017, 12:41 PM   #24
bikendan's Avatar
Yep, the resettable fuse is a common cause to the battery not being charged by the converter.
You still should test the battery with a hydrometer, when not plugged into shore power.
Draining the battery down that far, could've damaged a cell.
Old 01-12-2017, 05:51 AM   #25
DouglasReid's Avatar
Originally Posted by Mr. Dan View Post
X2... and notice "LOAD TEST" - not the same as checking voltage post to post.
X4, what he said!
2009 Chevy Silverado 2500HD CCSB LTZ Diesel, Fumoto Oil Drain Valve, Turbo Brake activated, 39 gal Aux Tank W/ Fuel Pump transfer, Air Lift Loadlifter 5000 air bags.
DouglasReid is offline   Reply With Quote
Old 01-12-2017, 07:41 AM   #26
Newly Retired
Steveboe's Avatar
I would suspect the battery. They have a limited life.
Steveboe is offline   Reply With Quote
Old 01-12-2017, 07:56 AM   #27
Especially running one down and not recharging properly. People assume (falsely) that a 20 minute charge 'tops' of the batteries and that's completely false.
SidecarFlip is offline   Reply With Quote
battery, charging, converter
