Old 01-10-2017, 01:32 PM   #1
thestrangebrew's Avatar
Battery not charging, may need new converter what to look for?
Long story short, I've had my trailer for about 2 years and never had a problem till now. For some reason, my battery isn't charging when plugged into my outlets at the house. I'm a complete noob when it comes to electricity. When I plug in my trailer to an outlet at home, I get power, ie lights etc. work, but my battery isn't charging. This is the first time it's happened, as before our last trip in June, my battery charged just fine. I've checked the 40 amp fuses at my panel, and they both look ok, which leads me to believe I need a new converter. What do I need to look for when replacing it? Are they all pretty much the same? Size/dimension wise, do units all fit the same? Which amps should I get etc? We're leaving on a trip Friday, is this a relatively easy job? Thanks.
Not sure if this helps, but a buddy has a portable charger he hooked up to my battery and was able to charge it.
2014 F-150 SCREW Ecoboost 4x4.
2014 Rockwood Roo 233s GVWR #6402
thestrangebrew is offline   Reply With Quote
Old 01-10-2017, 02:05 PM   #2
Flybob's Avatar
Check the resettable breaker on the tongue. ( see below). Pull the two 40A fuses and test them it can be hard to determine if they are good in while in the panel If you need to replace the converter most are the same footprint. I suggest Progressive as they do a better job.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 65W solar panels
Old 01-10-2017, 02:15 PM   #3
Thanks! Bikendan informed me of this breaker on a different thread in the Roo section. I'll pick up a few 40 amps just in case and look at the converters if resetting the breaker doesn't do the trick!
Old 01-10-2017, 02:21 PM   #4
Do you own a multi-meter and know how to use it?
Basic, simple tests will tell you what's going on before you spend a bunch of money throwing things at it.
2016 Flagstaff 8529IKBS Diamond Package 5th Wheel
Ford F-Series SCREW 4x4
TST Tire Monitor - Sinemate 3500w Gen.
Days Camped: '15=22 '16=46 '17=8
Old 01-10-2017, 03:28 PM   #5
Hi,
I had a brief encounter with this exact issue the other day. All 12 volt systems worked inside, but my monitoring equipment showed the battery wasn't charging.
Turns out I had inadvertently hit the battery cutoff switch. When I repositioned it, the converter immediately started charging the battery.
FWIW.
Rich Phillips
Rich Phillips
2009 K-2500 Duramax
2014 Silverback 33RL
richp is online now   Reply With Quote
Old 01-10-2017, 03:34 PM   #6
Thanks richp, but the cutoff switch is in the correct position to charge. Appreciate it though! @5picker I do own a multi-meter. My ability to use it is questionable though lol.
Old 01-10-2017, 03:38 PM   #7
PhoneDude 8289's Avatar
When all else fails before spending any money pull the battery and have it tested to see if it will take a charge. Most places that sell batteries will load test them for free.
Lifted 2014 8289WS Diamond pkg
2014 Ram 2500 4wd SB DC TCD
PhoneDude 8289 is offline   Reply With Quote
Old 01-10-2017, 03:49 PM   #8
Mr. Dan's Avatar
X2... and notice "LOAD TEST" - not the same as checking voltage post to post.
SEARCH is your friend!
Nights Camped: '13 = 49 / '14 = 74 / '15 = 74 / '16 = 85 / '17 = 54; booked = 12
Old 01-10-2017, 03:50 PM   #9
My buddy charged it with his portable charger when I stored it at his house on Saturday. I assume it held a charge because I was able to operate my power jack. Come Sunday, no juice in the battery. Of course something always comes up before a trip right? lol
Old 01-10-2017, 04:22 PM   #10
Herk7769's Avatar
There is a converter "load test" to see if the converter is OK as well.
It may be putting out 13 plus volts "no load", then wimp out under load.
This procedure is for the 55amp converter.
HAM CALLSIGN - KC3FFW
battery, charging, converter
