Old 10-30-2012, 02:29 AM   #1
Battery over charging at night
2011 Georgetown: Just replaced the two house batterys because they kept boiling over and setting off the alarm at night time when most of the 12 volt systems were not in use. They were about two years old. Have replace one inverter as well. The new batterys have been in use for 5 days , now the alarm has started go off around 1am. I assume these batterys are over charging. I started disconnecting the house batterys with the disconnect switch at night and connecting back up in the morning. Everthing seems to to be fine as long as a lot of 12 volt systems are in use. Is there a voltage charging regulator in the system that is suppose to keep the house batterys from over charging? Any suggustion would be appreciated...Larry
Flicker is offline   Reply With Quote
Old 10-30-2012, 06:18 AM   #2
TURBS's Avatar
Need to trouble shoot your converter.
Old 10-30-2012, 07:03 AM   #3
Herk7769's Avatar
Yes, sounds likely your converter is locked in "bulk" charging and is not switching to "FLOAT" as the battery gets topped off. It most likely needs replacing.
See the stages in the attached WFCO converter manual.
File Type: pdf Manual - Power Distribution Center WF-8900 English.pdf (1.89 MB, 22 views)
HAM CALLSIGN - KC3FFW
Old 10-30-2012, 07:37 AM   #4
TURBS's Avatar
To further herks post what is make and model of converter?
With that we can help you get the correct trouble shooting flow chart.
Turbs
Old 11-01-2012, 12:32 PM   #5
It is a WFCO 65 amp, Model WF9865.
When I installed it I didn't see any switches, so I assumed all function were automatic...Larry
Old 11-01-2012, 03:14 PM   #6
Herk7769's Avatar
They are. It is switched internally by voltage sensing circuits.
As the voltage of the battery increases, the stages are switched to avoid overcharging.
battery
