Old 11-18-2013, 01:07 PM   #11
Lloydg's Avatar
Send a message via AIM to Lloydg Send a message via MSN to Lloydg Send a message via Yahoo to Lloydg
Originally Posted by awwall View Post
I personally would bring it home and put a battery tender on it. Letting a battery go dead is one of the worse things you can do. ed.
That's my thought, too. I'm going to retrieve it this week, keep it charged at home and reinstall it before we leave for Florida.
Heartland Big Country 3150RL
2013 Ford SD F250 4x4 SC; 6.2
Reese 18K Elite w/slider - Ada, Michigan
Lloydg is offline   Reply With Quote
Old 11-18-2013, 01:11 PM   #12
Phat Phrog Stunt Crew
awwall's Avatar
Very wise move....
Wayne & Susan Biloxi,Ms
2012 GeorgeTown 351DS...2015 Ford Focus/Brake Buddy
FROG Member
awwall is offline   Reply With Quote
Old 11-18-2013, 03:09 PM   #13
If you don't disconnect the battery you may have the converter and the Battery Tender both feeding the battery. That would defeat the purpose of the Tender.
DSurette is offline   Reply With Quote
Old 11-18-2013, 03:38 PM   #14
DAISY BOYKIN's Avatar
Very wise move--------------
Lloydg, very wise move on removing the battery to keep it charged. Come on down to our great state of Florida, But bring lots of $$$$$ we need it.
When you cross the state line you will see a sign that says "KEEP FLORIDA GREEN", that simply means bring lots of $$$$$!
Sid, Lois & HRH MISSY Terrible 2s SHIH TZU
2011 ROCKWOOD 8285 WS
2014 F-250 KING RANCH PS/SD/6R140/BFT
DAYS CAMPED 2018 21 DAYS
DAISY BOYKIN is offline   Reply With Quote
Old 11-26-2013, 08:03 PM   #15
Makin' Life Simple
skisteveski's Avatar
Think "convenience" when having a disconnect switch. Otherwise you need to get the wrench, pull the cover, place the wrench (5/8ths most likely), and loosen and remove the wire. Reverse all this to put it back on. The switch is a 45deg turn and the battery is fully disconnected.NOW...if you NEVER want to disconnect the batt (except when replacing it) because you have a batt tender, then you really don't need the switch.
skisteveski is offline   Reply With Quote
Old 11-27-2013, 02:54 PM   #16
Battery Disconnect Switch
With the disconnect switch OFF, you can't use any 12V in the unit relying on the battery. This has no effect on using a floater to keep your battery charged.
J Autry is offline   Reply With Quote
Old 11-27-2013, 04:08 PM   #17
Witch Doctor's Avatar
You have to know what else is connected to the battery. Alot of the CO alarms are connected pass the disconnect. So it would be pulling amps with your disconnect turned off. You are better off taking it home or your battery will be dead when you go back.
Rockwood #8289 WS 2012
F250 6.0 / Husky 16k
With 4 point leveling system
Old 11-27-2013, 05:27 PM   #18
IMO, if your battery disconnect doesn't disconnect all of the parasitic loads (like propane/CO detector), it's wired wrong. That's the whole purpose of the silly thing.
Old 11-27-2013, 05:41 PM   #19
You would think so, But mine is wired directly to the positive terminal. I know that that is the case because I disconnected it at the battery post and it shut it off. My solution was to add a SPST switch next to the CO unit in the trailer. They could have made a mistake at the factory just as my disconnect pulls out for on and push in for off. I had to add a plate in front of it being my load shifted during travel and shut down my 12V. It's attached to the floor of the basement not on the upper wall. I another great design by FR. So you shouldn't make blanket statements like that. I would be more then happy to post pictures.......
Old 11-27-2013, 06:00 PM   #20
Lloydg's Avatar
Are you sure that the switch should not work that way? Was it suppose to work like a safety switch that can be turned off simply by depressing the button?
battery
