Old 11-27-2013, 06:15 PM   #21
I think of it like an old car light switch. You pulled it out to turn the lights on.
Old 11-28-2013, 02:01 AM   #22
Witch Doctor's Avatar
Originally Posted by Lloydg View Post
Are you sure that the switch should not work that way? Was it suppose to work like a safety switch that can be turned off simply by depressing the button?
Oh I'm positive on that is the way it works, I have even talked to Rockwood Factory on it. They said that they were going to change it, but as of last month they said they still are using them. I also called my dealer because I think it's dangerous the way it is set up and where it is located. They got the same answer it's in the pipeline being discussed.I even asked the question on the Factory tour.
Rockwood #8289 WS 2012
F250 6.0 / Husky 16k
With 4 point leveling system
Witch Doctor is online now   Reply With Quote
Old 11-28-2013, 02:03 AM   #23
That is exactly like what it is... good way to describe it
battery
