11-17-2013, 10:48 PM
Battery question
We leave our camper plugged up all the time, even when not in use. Will this cause any issues with the battery/on board charger when it gets cold/freezing?
Thanks, Philip
2014 30QBSS - Salem Travel Trailer
2000 Ford Excursion 7.3 4X4
11-17-2013, 10:57 PM
Thanks, Philip
Shouldn't if you check the water in the batteries about every 2 or 3 weeks.
11-18-2013, 08:04 AM
Thanks, Philip
With a 2014 you should have a power center converter with 3 stage charging.
Float mode should not boil the water out of a wet battery with excessive current as float will drop charging current to that necessary to replace losses due to parasite current loss (internal resistance and about an amp of "junk" that runs in the background).
However, you should "check on" the camper about once a month to look for damage or leaks and during that check a peek under the caps will assure you that all is still "OK".
Lou & Freya the wonder dog
2019 Flagstaff 8529FL
11-18-2013, 09:06 AM
I suggest you read this post (and other earlier experiments by this gentleman): http://www.forestriverforums.com/for...tml#post482734
The WFCO "3-stage" chargers don't appear to work very well.
I suggest that you either upgrade your Converter to a Progressive Dynamics, or unplug your RV except for about a day a month.
11-18-2013, 09:17 AM
Another solution is to install a disconnect switch at the battery and use a Battery Tender to keep the battery conditioned.
11-18-2013, 09:22 AM
X2
Bill
Life is a journey, not a destination.
2005 Georgetown 359ts
Bill & Virginia, Kentucky
Nights camped in 2011...78 , 2012...73,
Nights camped in 2013...123, 2014 ...101
11-18-2013, 09:57 AM
Originally Posted by bend302
X2
Bill
X3. Far and away the best solution.
2021 F350 Lariat 7.3 4X4 w 4.30s, 2018 Wildcat 29RLX
Red Green coffee mugs
11-18-2013, 01:56 PM
My 5er is stored away from home and has no access for electric hookup. The battery was fully charged when put into storage on Nov.1 and the battery disconnect turned off. Will be leaving for Florida the last week in January. Should I bring the battery home and keep charged or will there be a decent charge when we leave? I don't want it to go completely dead.
Heartland Big Country 3150RL
2013 Ford SD F250 4x4 SC; 6.2
Reese 18K Elite w/slider - Rockford, Michigan
11-18-2013, 02:02 PM
Phat Phrog Stunt Crew
I personally would bring it home and put a battery tender on it. Letting a battery go dead is one of the worse things you can do. Sucks the life right out of it. Sometimes when they go dead, they stay dead. No way to bring back to life. Doesn't happen all the time, but does happen. Either way, you are doing your battery an injustice by not keeping it charged.
Wayne & Susan Biloxi,Ms
2012 GeorgeTown 351DS...2015 Ford Focus/Brake Buddy
FROG Member
11-18-2013, 02:03 PM
Happy owner SOB
I use a battery tender but have not found a reason to use a disconnect switch. Am I missing something?
11-18-2013, 02:07 PM
Originally Posted by awwall
I personally would bring it home and put a battery tender on it. Letting a battery go dead is one of the worse things you can do. ed.
That's my thought, too. I'm going to retrieve it this week, keep it charged at home and reinstall it before we leave for Florida.
11-18-2013, 02:11 PM
Very wise move....
FROG Member
11-18-2013, 04:09 PM
If you don't disconnect the battery you may have the converter and the Battery Tender both feeding the battery. That would defeat the purpose of the Tender.
11-18-2013, 04:38 PM
Very wise move--------------
Lloydg, very wise move on removing the battery to keep it charged. Come on down to our great state of Florida, But bring lots of $$$$$ we need it.
When you cross the state line you will see a sign that says "KEEP FLORIDA GREEN", that simply means bring lots of $$$$$!
Sid & HRH MISSY, SHIH TZU
2019 WILDCAT 28 SGX
2014 F-250 KING RANCH PS 6.7L/SWD/6R140/BFT
DAYS CAMPED 2023 69 DAYS
[SIGPIC][/SI[SIGPIC]
11-26-2013, 09:03 PM
Makin' Life Simple
Think "convenience" when having a disconnect switch. Otherwise you need to get the wrench, pull the cover, place the wrench (5/8ths most likely), and loosen and remove the wire. Reverse all this to put it back on. The switch is a 45deg turn and the battery is fully disconnected.NOW...if you NEVER want to disconnect the batt (except when replacing it) because you have a batt tender, then you really don't need the switch.
11-27-2013, 03:54 PM
Battery Disconnect Switch
With the disconnect switch OFF, you can't use any 12V in the unit relying on the battery. This has no effect on using a floater to keep your battery charged.
11-27-2013, 05:08 PM
You have to know what else is connected to the battery. Alot of the CO alarms are connected pass the disconnect. So it would be pulling amps with your disconnect turned off. You are better off taking it home or your battery will be dead when you go back.
Coachmen M/H
Concord
2018 / 300 DSC
11-27-2013, 06:27 PM
IMO, if your battery disconnect doesn't disconnect all of the parasitic loads (like propane/CO detector), it's wired wrong. That's the whole purpose of the silly thing.
11-27-2013, 06:41 PM
You would think so, But mine is wired directly to the positive terminal. I know that that is the case because I disconnected it at the battery post and it shut it off. My solution was to add a SPST switch next to the CO unit in the trailer. They could have made a mistake at the factory just as my disconnect pulls out for on and push in for off. I had to add a plate in front of it being my load shifted during travel and shut down my 12V. It's attached to the floor of the basement not on the upper wall. I another great design by FR. So you shouldn't make blanket statements like that. I would be more then happy to post pictures.......
Coachmen M/H
Concord
2018 / 300 DSC
11-27-2013, 07:00 PM
Are you sure that the switch should not work that way? Was it suppose to work like a safety switch that can be turned off simply by depressing the button?
