Old 11-17-2013, 09:48 PM   #1
Battery question
We leave our camper plugged up all the time, even when not in use. Will this cause any issues with the battery/on board charger when it gets cold/freezing?
Thanks, Philip
2014 30QBSS - Salem Travel Trailer
2000 Ford Excursion 7.3 4X4
pkthomas is offline   Reply With Quote
Old 11-17-2013, 09:57 PM   #2
Thanks, Philip
Shouldn't if you check the water in the batteries about every 2 or 3 weeks.
Old 11-18-2013, 07:04 AM   #3
Herk7769's Avatar
Thanks, Philip
With a 2014 you should have a power center converter with 3 stage charging.
Float mode should not boil the water out of a wet battery with excessive current as float will drop charging current to that necessary to replace losses due to parasite current loss (internal resistance and about an amp of "junk" that runs in the background).
However, you should "check on" the camper about once a month to look for damage or leaks and during that check a peek under the caps will assure you that all is still "OK".
HAM CALLSIGN - KC3FFW
Old 11-18-2013, 08:06 AM   #4
I suggest you read this post (and other earlier experiments by this gentleman): Winterizing Question
The WFCO "3-stage" chargers don't appear to work very well.
I suggest that you either upgrade your Converter to a Progressive Dynamics, or unplug your RV except for about a day a month.
Old 11-18-2013, 08:17 AM   #5
Another solution is to install a disconnect switch at the battery and use a Battery Tender to keep the battery conditioned.
DSurette is offline   Reply With Quote
Old 11-18-2013, 08:22 AM   #6
bend302's Avatar
X2
Bill
Life is a journey, not a destination.
2005 Georgetown 359ts
Bill & Virginia, Kentucky
Nights camped in 2011...78 , 2012...73,
Nights camped in 2013...123, 2014 ...101
bend302 is offline   Reply With Quote
Old 11-18-2013, 08:57 AM   #7
acadianbob's Avatar
Originally Posted by bend302 View Post
X2
Bill
X3. Far and away the best solution.
2018 F250 Lariat 6.2 4X4 w 4.30s, 2018 Wildcat 29RLX
2003 Yamaha FJR1300, Demco Premiere Slider
Red Green coffee mugs
Old 11-18-2013, 12:56 PM   #8
Lloydg's Avatar
Send a message via AIM to Lloydg Send a message via MSN to Lloydg Send a message via Yahoo to Lloydg
My 5er is stored away from home and has no access for electric hookup. The battery was fully charged when put into storage on Nov.1 and the battery disconnect turned off. Will be leaving for Florida the last week in January. Should I bring the battery home and keep charged or will there be a decent charge when we leave? I don't want it to go completely dead.
Heartland Big Country 3150RL
2013 Ford SD F250 4x4 SC; 6.2
Reese 18K Elite w/slider - Ada, Michigan
Lloydg is offline   Reply With Quote
Old 11-18-2013, 01:02 PM   #9
Phat Phrog Stunt Crew
awwall's Avatar
I personally would bring it home and put a battery tender on it. Letting a battery go dead is one of the worse things you can do. Sucks the life right out of it. Sometimes when they go dead, they stay dead. No way to bring back to life. Doesn't happen all the time, but does happen. Either way, you are doing your battery an injustice by not keeping it charged.
Wayne & Susan Biloxi,Ms
2012 GeorgeTown 351DS...2015 Ford Focus/Brake Buddy
FROG Member
awwall is offline   Reply With Quote
Old 11-18-2013, 01:03 PM   #10
Happy owner SOB
I use a battery tender but have not found a reason to use a disconnect switch. Am I missing something?
sheriff1 is offline   Reply With Quote
battery
