Old 09-16-2018, 05:00 PM   #1
Battery questions?
So our new 372rd came with 2 batteries. I have noticed some things lately that trouble me. One, my battery disconnect switch does not kill the power. It does kill the power to the slides, but thats about it. lights and other stuff still have power. The second battery is not affected at all by the switch. I have to pull the cables off to disconnect it. ( could I just switch the inverter off instread?) Shouldn't my batteries be wired together? MY residential fridge only runs off one of the batteries. When I go to the control panel in the rv, it will say my batteries are at %100,(not plugged into shore power) but the battery running my fridge will be low? I also figured out that my truck is not charging both batteries, nor will my solar port. The only way to charge the second battery is to hook my solar directly to it via alligator clips, or to run the generator or shore power. On our DP, when I would hit the disconnect switch, it killed the power to everything. That is how I would like this setup to be.
"Slightly Modified" 2013 Ram Cummins MegaCab
2018 Heritage Glen 372RD 43ft.
k_allison510 is offline   Reply With Quote
Old 09-19-2018, 01:23 AM   #2
Kirk S's Avatar
Nice rig!
Normally I wouldn't comment since I don't own a rig like yours but I see you asked 2 days ago with no response. If someone with your model has different ideas they may be a better source of help than me.
First, be absolutely certain there is no reason your batteries are connected separately. If there is I would like to know as well.
It is possible that the batteries were installed improperly by the dealer and Forest River would have no idea.
If you discover the current configuration is incorrect and new means still under warranty you should get your dealer to connect your batteries properly. If you are not close to your dealer you should get Forest River to authorize another dealer to do it, if they will agree to it.
If you are sure you know how, you could do it yourself but if something went wrong it would be on you.
You would need to disconnect truck, solar, shore power, inverter and both negative cables to be sure everything is off before reconfiguring.
I can't think of a reason your batteries would not be wired together in parallel. This still gives you 12 volts but doubles your capacity. Your disconnect switch should shut off most 12 volt items, your truck and solar should charge both batteries.
If you are connected to any charging source it's likely your battery level monitor will always show 100 % so it's best to check it when not connected to shore, truck or solar and a simple digital meter set on DC volts would show you actual voltage at the battery posts.
Goid luck and please post your solution when you find it.
Diagram attached.Click image for larger version
Kirk
2017 Forester 3051S
Kirk S is offline   Reply With Quote
Old 09-19-2018, 05:06 AM   #3
World Wide Wanderer
wahoonc's Avatar
Not familiar with your specific unit, however it sounds like something isn't wired up quite right. Typically the dealer installs the batteries not the factory. Battery disconnect switches typically don't disconnect everything. On my unit the various detectors like CO and LP bypass the disconnect switch along with a couple of lights.
Aaron
Aaron & Rhonda
wahoonc & Airangel60
2016 Coachmen Concord 300DS
2015 Fusion Hybrid following along
wahoonc is offline   Reply With Quote
Old 09-19-2018, 03:24 PM   #4
Missing some critical information to help us provide a good solution.
In the meantime, I offer the following:
On paralleling 12V batteries, the result from outside the battery box is a single larger battery. For successful paralleling the batteries have to be very close equal - capacity, charge state, age, number of cycles, etc. If they are not equal, the higher voltage battery tries to charge the lower voltage battery up to its level. The current involved can be cable melting if the mismatch is severe enough - don't ask me how I know.
A reason (not very good) for not paralleling in your case is the residential fridge. I don't know how much power the fridge takes, but I'm guessing at least 180 watts - which equals 15A at 12V. If there is not power coming into the batteries, this could draw them flat in less than 6 hours of fridge run time. The previous owner may not have realized this, and found himself out of battery to operate the slides. But to fully understand what is going on we need to know the size and type of batteries you have, as well as the power requirements of the fridge.
I will not try to explain the miswiring of the disconnect switch. I agree, I like my disconnect to kill all battery connections - period. But because the slides and inverter and tongue jack (and leveling system and solar if equipped) are wired directly to the battery, the disconnect has to be located at the battery, and not at the panel.
Since my A-frame didn't come with a disconnect, I installed my own on the outside of the battery box, which is located on the tongue.
The panel lights require understanding to interpret correctly. The panel lights are a poor excuse of a voltmeter. When you are plugged into shore power, you are reading the output voltage of the converter, not the state of the batteries. And it takes a few hours of no charge being applied for a voltmeter to give a reasonable approximation of battery state of charge.
Another question pertains to your inverter. Does it charge batteries as well as provide power to the fridge? I'm guessing so, with your converter charging the other battery. If the inverter is also a battery charger, how does it get 120V power to charge batteries?
I'm sorry I'm not much help. Without knowing some of this information, there are just too many possibilities to provide you with good info.
Fred W
2019 Flagstaff T21TBHW A-frame
Old 09-19-2018, 05:23 PM   #5
Fred W
Thanks for replies fellas. I will try and fill in some of the blanks. The trailer is brand new. We have had it for about 3 weeks now. We are about 4 hours from the dealer we bought it from but are taking it back in late October /early November for our 90 day shakedown work.
The only thing I know about the batteries right now is that they are interstate deep cycles. I will have to go get the actual specs off them. (trailers in storage). The dealer did install the batteries because when we looked at the unit initially, it didnt have batteries installed. The batteries are actually in 2 different locations. The one the fridge runs on is in the pod in the front of the trailer (under the pin box) The other is in its own pod on the side of the trailer at the front. They are not very far apart, by I figure it will take at least 5 feet of cable to attach them in parallel. But I figured that they both ran to a junction box of some kind to put them in parallel. Guess I am wrong about that. Our sales lady (i know I know) told us that the fridge would run for about 10 hours with out shore power, so I figured that both batteries were powering it.
Something that confuses me is that when the fridge battery starts getting low (about 10.5v) the inverter will start beeping and telling me that its going into shutdown to protect the battery. So I turned the inverter off. But even with it off, I still have lights. I didnt check if anything else will work but I suspect the slides and jacks will also work since I know they run off the other battery.
The battery disconnect seems to only shut off the 2nd battery. (the non fridge battery) I guess I can live with that if turning the inverter off will essentially do the same thing for the first battery.
Long story short, I am going to discuss these issues with the dealer but I wanted to be educated so I can argue if they say thats the way its supposed to be, and maybe it is? I guess if worse came to worse, I could just go buy another battery and wire it in parallel to the fridge battery.
Also, When I am completely disconnected from any power (shore, gen. solar) and my inverter is going into shut down,(fridge battery is close to 10.5v) the panel will show that my batteries are %100, which leads me to believe that only the 2nd battery is wired to that panel. And apparently it only powers my lights, slides, jacks, and awning. If I could only choose one battery for it to display, I would rather the fridge battery be on it.
Again, thanks for the replies, I really appreciate it.
Old 09-19-2018, 05:26 PM   #6
Also forgot the mention that my inverter does charge both batteries when I am plugged into shore power or generator.
Old 09-19-2018, 05:32 PM   #7
Herk7769's Avatar
The reason the CONverter is not connected to both batteries and why the batteries are not connected in parallel is because the INverter used with the residential fridge is an INVerter/Charger.
One of the batteries is dedicated to the fridge and is charged when the INverter is connected to shore power (120VAC). The INverter goes into "pass through" mode to supply the fridge with 120VAC power. At the same time, while it is in "Pass-through", it charges the dedicated fridge battery.
The camper's CONverter charges the camper's dedicated "house" battery when connected to 120VAC shore power.
The two batteries are not connected to each other and serve two different purposes.
HAM CALLSIGN - KC3FFW
Old 09-19-2018, 07:21 PM   #8
My mind is literally blown.....Thanks you for clearing that up. So....still have a question. I have a xantrex freedom x 1200 in one of the front pods. That is what beeps when the fridge battery is getting low. Is that my INverter for the fridge?
Also, just to clarify, should my truck and solar port be charging both batteries? Or just the "house" battery?
Old 09-20-2018, 05:30 AM   #9
I don't know whether the residential fridge was a dealer or factory installation - but it doesn't matter. As Herk pointed out, you have 2 totally separate electrical systems - one for the fridge, and one for everything else.
Which works well in the intended usage scenario - your camper is plugged in while in storage, you drive a day or less to your campsite, and your campsite has electrical service. The battery is only there to power the fridge while you are driving the less than 10 hours.
Whoever designed your system did not intend for it to run 24 hours + on a single 80AH battery. Because the fridge battery has already been taken down to 10.5 volts (dead battery) once or twice, putting that battery in parallel would be a mistake that will likely destroy the better battery in short order.
Before we can make recommendations for a better system for your usage, we need to understand how much power the fridge needs (should be a plate on the back or at least a model number), and how many hours/days between plugging in the 5th wheeler.
Charging batteries with your tow vehicle is the wild card that is hard to predict without you doing a series of measurements. But usually, the tow vehicle does far less battery charging than we would like it to do.
look forward to hearing the specs on the residential fridge and usage
Fred W
Old 09-20-2018, 04:44 PM   #10
The Xantrex is your inverter. It converts the fridge battery 12VDC to 120VAC for the residential fridge. The Xantrex may, but not likely, also power an AC outlet besides the fridge. Think of your residential fridge as a separate branch off the AC panel of your camper. The 120V power comes in when you are plugged in, and is distributed through the AC circuit breakers. One of these breakers powers the Xantrex which powers the residential fridge and has a battery it both charges and uses. The Xantrex draws from the fridge battery when there is no AC power coming in, and charges the fridge battery when there is.
It is a question worth asking - but I don't know if your dealer will know - whether or not the tow vehicle charge line also ties into your fridge battery. It probably does, but might not.
The rest of your electrical is RV standard 120V/12V with its own house battery and converter to charge it when plugged in.
Your tow vehicle - at very best, and could be 8-10 - might provide 15 amps to the trailer, but only when the engine is running. That 15 amps has to be take care of all needs in your camper while towing down the road, including the residential fridge, battery charging, running lights, all parasitic loads. The residential fridge sucks at least 15 amps at 12V, so you are depleting the fridge battery while towing. And even more so when you turn the engine in your tow vehicle off.
FWIW, your lights, thermostats, stereo, control boards in your camper are all 12V, not 120V. These operate off the house battery and converter.
Fred W
battery
