Old 01-24-2014, 01:39 PM   #1
Battery Quick Connect
We will be storing out TT at a storage facility. Although it is gated, I think I want to remove the battery while in storage. I have used a quick connect for race car batteries as linked to below. Anyone see an issue in using this for an RV battery?
Winch Power Connector Plug Kit for Quick Disconnect from Battery - Amazon.com
Also, does anyone remove their propane tanks in storage?
Lee and Anne
2016 F250 2WD CC SB XLT 6.2 3.73 3,295 lb payload cap.
2014 Salem Hemisphere 282RK 8k lbs loaded, Equal-i-zer WDH, TST 507 TPMS
2017: 4 nights camped, 12 booked
Teamfour is offline   Reply With Quote
Old 01-24-2014, 03:04 PM   #2
HONDAMAN174's Avatar
I was pulling my batteries so they didn't get stolen with my popup. With my new trailer, I bought these :
http://b-drvbatterylock.com/
Batteries are always good for thieves cause they can either use them or get $20 for the core. Have seen some people chain their propane to the frame but I do not.
Just glad to get away
Old 01-24-2014, 03:43 PM   #3
Todouble's Avatar
I chain up my propane. I'm that guy. On my TT I used to take battery home from storage lot after every trip. The new fiver now has it locked in front compartment so I just leave it and hit the battery disconnect switch.
Todouble is offline   Reply With Quote
Old 02-07-2014, 08:27 AM   #4
I've had 2 battery's freeze. One busted the other started pushing acid out upon charge. If not plugged in or on solar charge its probably a good ideal to remove and put on a trickle charge if freezing weather for days is expected. May be another reason besides thievery
Kickingupmudd is offline   Reply With Quote
battery
