Old 07-16-2012, 06:49 PM   #11
VinceU's Avatar
Bill for your use it's best value, my sears battery was as good as the Interstates. Suspect they are made very close together in a faraway place, just change the dye color for different labels. You know like sneakers. Watch the ratings and match your existing terminals/lug connectors.
Old 07-16-2012, 08:37 PM   #12
RPAspey's Avatar
one observation, you stated you charge the battery every other week. you might be letting you battery discharge too much, causing a little damage each time. if you don't have a battery disconnect, consider charging more often.
by the way, the original battery in my camper lasted almost 8 years. it was an interstate deep cycle. my new ones, Trojan t-145s.
2000 Cherokee 29BH with 6V batteries, LED lights & 400 watts of solar power, flipped axles and raised. 2007 Tundra 5.7L DC-LB with lots of mods. C-co, 8/158th AVN Maint.
RPAspey is offline   Reply With Quote
Old 07-17-2012, 11:30 AM   #13
fivecodys's Avatar
That's a good point.
I was trying to avoid over charging and boiling off the water.
I will consider changing my charging schedule.
Thanks for the input.
Bill
2009 Flagstaff 8528 RKSS
2007 Toyota Tundra DC 5.7L V8
Pullrite Superglide 14K
Air Lift 5000
Prodigy Brake Controller
"I've got a mind like a steele.. a......a steele......um.....uh...... what's that thing called again?
fivecodys is offline   Reply With Quote
Old 07-17-2012, 11:41 AM   #14
Dave_Monica's Avatar
Bill
If the camper is parked at home, why don't you plug it into shorepower. The convertor's charger will trickle charge it. Mine's always plugged in at home...2 1/2 years and not issue. If you're concerned about overcharging, just put a 'battery tender' on it.
Dave
Old 07-17-2012, 06:44 PM   #15
fivecodys's Avatar
Dave
Hey Dave.
How's it going?
I am hooked to shore power here at the house.
I flip the breaker off (no pun intended) and let the trailer sit for a week or so, then I turn it on for a few days and then back off.
Roughly a two week cycle.
I was warned about leaving the trailer plugged in all the time and how it could harm the battery by boiling off the water.
Not sure if that's true or not.
I did get 4-1/2 years out of the battery so I'm not really complaining.
I have been pretty faithful to check the battery's water level.
Seems like I'm always out there dinking around with something.
You guys still ejoying the rig?
Bill
Air Lift 5000
Old 07-17-2012, 07:36 PM   #16
Hey Dave.
How's it going?
Bill
Hey Bill...our camper is plugged into shorepower 365 days/year with the convertor powered up. I believe that newer campers all have convertors with 3 stage battery charging. I just check the battery water levels twice per year usually when winterizing and de-winterizing.
Still really enjoying the camper...no issues to speak of. This year we're doing few camping trips but staying longer.
I usually don't point out spelling/grammar miscues but it should read 'I'm always out there drinking a round with someone'!
Happy camping...
Dave
Old 07-17-2012, 07:54 PM   #17
TURBS's Avatar
I'm with Dave mine is plugged 365 24/7
Unless running down the road.
Old 07-18-2012, 02:33 PM   #18
fivecodys's Avatar
When I get the new battery I will give that a try.
It's not a problem as I put in a 30 amp circuit at the house so we could run the A/C in the trailer whenever we were loading/unloading.
Thanks to all for the input.
It is appreciated.
Bill
Air Lift 5000
battery
