Old 10-24-2014, 05:36 PM   #1
djkoester2's Avatar
Battery removal for winter storage.
Should I shut the main (or all breakers) off before removing the battery?? Thoughts please...
djkoester2 is offline   Reply With Quote
Old 10-24-2014, 05:56 PM   #2
Ford Idaho's Avatar
Given that the battery only supplies the 12 volt systems it is not necessary.
Just unhook the ground wire first you will be fine.
Old 10-24-2014, 05:57 PM   #3
djkoester2's Avatar
Is the ground wire the negative terminal?
Old 10-24-2014, 05:59 PM   #4
Ford Idaho's Avatar
Yes it is.
Old 10-24-2014, 05:59 PM   #5
djkoester2's Avatar
Thanks!
Old 10-24-2014, 06:02 PM   #6
Ford Idaho's Avatar
Old 10-25-2014, 04:16 PM   #7
WFD
How about when you re-connect the battery in spring...do you connect ground first or last.
2016 Chevy Silverado 2500 Duramax
2016 Rockwood 8289WS, Diamond Pkg.
WFD is offline   Reply With Quote
Old 10-25-2014, 05:04 PM   #8
rattleNsmoke's Avatar
It really doesn't matter. I'd make sure the main breaker or battery cut-off is thrown before reconnecting.
rattleNsmoke is offline   Reply With Quote
Old 10-25-2014, 05:23 PM   #9
Ford Idaho's Avatar
POS first then NEG, kind of a reverse the curse thing.
Old 10-25-2014, 05:29 PM   #10
And after removal of the battery, check the water levels, add distilled water if necessary (even though it says it is maintenance free) and put it on a small float charger like the BatteryMinder for the winter. Many suggest keeping it off the concrete by putting it on a board. Your battery will last twice as long.
MartyQ is offline   Reply With Quote
battery, storage, winter
