Old 08-05-2016, 11:00 PM   #11
MNtraveler's Avatar
Battery Replacement
Seems unlikely. What fuse is blowing? What circuit or appliance is on that fuse. As I just to be clear, it's a fuse not a circuit breaker? Is it one mounted on a wall right near the battery? (You said something about right up to the battery.)
Land of 10,000 Lakes
2016 Forester MBS 2401R
2016 Forester 2401R
MNtraveler is offline   Reply With Quote
Old 08-12-2016, 09:17 AM   #12
It is a 20Amp fuse right next to the battery. I believe it is the one that comes from the voltage regulator to charge the battery.
Leever2000 is offline   Reply With Quote
Old 08-12-2016, 11:12 AM   #13
MNtraveler's Avatar
That one shouldn't be blowing. It's a main circuit line problem. I would recommend taking it to the dealer for a full electrical check. Others here may have some suggestions, but I'm basing this on the nature of the issue and I'm inferring that you don't have an electrical background or the equipment to hunt down a high output, high draw or short circuit issue - and I mean no offense by that! I just don't want you to waste your time or even potentially get hurt.
Old 08-12-2016, 01:33 PM   #14
No offense taken - On that note does anyone have access to a schematic for the 2015 Coachmen Clipper 17BH? I would assume it would be pretty close to any 30 AMP system that has shore power hookup.
Shore power in to a voltage regulator to run/charge the 12VDC system and the direct link to the 110 VAC stuff (AC, microwave etc...)
battery, replacement
