Old 05-16-2014, 10:27 PM   #1
Battery required?
We placed our Sierra 28 on a camping site that we are going to stay at for a while. The RV will not be towed nor used without city power.
Are the batteries required to stay in place? Any harm in disconnecting them or removing them completely?
-Rick
rickymiata is offline   Reply With Quote
Old 05-16-2014, 10:35 PM   #2
Denver, CO
garbonz's Avatar
Depends on the converter that you have. Some can handle not having a battery in the circuit, some can't. Look up the info on your converter and see what it says.
If you do leave a battery hooked up, make sure you check the voltage and battery water frequently or you may need a new one after a few months, as it may lose water with the constant float voltage and dry up and be ruined.
2017 Fuse 23T
Old 05-17-2014, 02:52 PM   #3
Herk7769's Avatar
The WFCO converters are designed to operate in conjunction with a battery and the battery actually serves to stabilize ripple in the DC output. It makes for very stable power to your computer components.
HAM CALLSIGN - KC3FFW
Old 05-17-2014, 04:56 PM   #4
Iggy's Avatar
X2
Old 05-17-2014, 07:28 PM   #5
X3
Would like to add if you get a VRLA sealed deep cell battery you will not have to keep check on the water. The vent valves are designed to reclaim the evaporated water from charging.
Sent from my SCH-I545 using Forest River Forums mobile app
2007 GMC 2500 Duramax Crew Cab LB
2008 5th Wheel Cardinal 36LE
R Whitlow is offline   Reply With Quote
Old 05-17-2014, 07:58 PM   #6
VinceU's Avatar
X4 The battery serves as a energy bank for larger loads, hydraulic pump or slide operation without overloading the converter.
VinceU is online now   Reply With Quote
Old 05-19-2014, 10:31 PM   #7
Thanks for the advice
I want to thank all of you. It makes sense and I will keep an eye on my batteries.
battery
