Old 02-07-2008, 11:50 PM   #1
jeffnjen1's Avatar
Question Battery Set up and Generator
I am looking for some suggestions on the best battery set up for boondocking and recommendations of a small, lightweight, quiet, and reasonably priced generator. We will be camping a few times a season with out any hook up and for a 4-5 day stretch each time. We would be running a 19 LCD t.v., DVD player, furnace fan and lights I have read that 2 6-volt golf cart batteries would provide power longer then the standard 12 volt battery provided with the trailer. I am pretty sure we would drain the batteries in less then 5 days no matter what battery set up we use hence the need for a generator to either run off of and/or to charge the batteries.
Thanks in advance for any advice.
Jeff
Jeff, Jennifer and 1 active 3 yr old boy
2002 Ford F-150 Super Crew
2007 Surveyor SV291
Minnesota
Our photos: http://www.forestriverforums.com/Pho...00&ppuser=1363
jeffnjen1 is offline   Reply With Quote
Old 02-08-2008, 02:06 PM   #2
Rockinwood's Avatar
We use A honda eu3000I, I know they are not inexpensive, but if you look on craigslist or classified, you might find a good deal on a used one, I have gotten the generic versions and have taken them all back, on the batterys, we have 2 12volt hooked up, we had to add a triangualr plate in front of the tounge jack so we could add another battery, works great when we dry camp in the Sierras.
2007 Rockwood 8317ss Reese Dual cam sway, 2002 Ford Excursion XLT V10,Prodigy Brake controller
Married DW 03/15/97 3 kids
Rockinwood is offline   Reply With Quote
Old 02-08-2008, 03:46 PM   #3
Rockinwood's Avatar
Saw this generator on amazon http://www.amazon.com/gp/product/B00...pr_product_top
Old 02-08-2008, 09:12 PM   #4
The Jolly Mon
NDJollyMon's Avatar
Send a message via Yahoo to NDJollyMon
I had 2-6 volts on my last trailer. Much more capacity than the factory setup. I never used a genny camping...but I use them at work. I like the Honda's too. We have the 1000, 2000, & 3000. For camping, I'd go 2000 unless you need to run the A/C...then go 3000. Yamaha makes some nice ones too.
Pete (Jolly Mon)
2018 Wildwood Grand Lodge 42 DLTS
-Seasonal Space, Northern MN.
-2017 Sylvan 8522 LZ LES/115 Merc/Sea Legs
NDJollyMon is offline   Reply With Quote
battery
