Old 07-23-2014, 10:29 PM   #1
Battery Solenoid wires became disconnected, Help!(Windsong)
Hi everyone! I'm attempting to help my father out who has recently purchased a 2002 Windsong. We have came across an issue with three wires that lead to one of the battery solenoids that have became disconnected. I've been searching around for wiring diagrams for a while and haven't been able to find anything. I've attached a picture of the issue and labeled everything just for clarity. Any help would be greatly appreciated!
Brent
brenb0 is offline   Reply With Quote
Old 07-24-2014, 10:47 AM   #2
Is this a motor home?
What is this solenoid for? for a starter? For a charger disconnect??
Going to need more info to fully help you out. 1 and 2 are the solenoid coil wires (to activate the solenoid). I'm not sure what wire 3 is going to. Do you have another pic of the back side of the solenoid that clearly shows where wire 3 is landed? It looks like it may be going to a relay to feed the solenoid coil but I can't tell from the pic.
Bmbrady77 is offline   Reply With Quote
Old 07-25-2014, 01:10 PM   #3
I took a second look at your pic just now...
On closer inspection..
C to 1
A to 2
B to 3
I can tell because, and I can't believe I missed it the first time, the terminals on the solenoid coil have labels with the wire color indicated. It's upside down, but you can clearly make out "Brown" on the right terminal, and "White" on the left. That only leaves the faded yellow wire which must go to the butt splice connector..
battery, windsong
