Old 09-07-2019, 03:07 AM   #1
Battery Switch
I have a 2017 Keystone High Montana, it has 2 battery switches which I just can't figure why unless each one has a separate function which I don't know. There is one switch located above the dual batteries in front compartment and one switch located where your water hookup compartment. Both are on/off switches and of course no booklet or info with the RV. Thanks
Racer310 is offline   Reply With Quote
Old 09-07-2019, 04:11 AM   #2
bikendan's Avatar
well, since your Montana is not a FR product, i think you'll need to post pics of both switches.
i doubt if it came with a model-specific owner's manual, since nearly all RV manufacturers only provide a generic owner's manual.
Equalizer WDH
Old 09-07-2019, 07:06 AM   #3
did you buy new or used?
if used this is just a guess. the one in the water compartment may be the factory installed one that does not disconnect all parasitic loads. the previous owner may have installed one in the battery compartment that removes all parasitic loads. again just a guess.
2015 cardinal model 3825fl
2015 dodge ram 3500 dually
CHICKDOE is offline   Reply With Quote
Old 09-14-2019, 04:02 AM   #4
2017 model bought new. Sorry picture are side ways
Name:	RV battery switch-1.jpg
ID:	214929   Click image for larger version
Name:	RV battery switch - 2.jpg
Old 09-14-2019, 04:47 AM   #5
bikendan's Avatar
The first pic looks factory while the second pic looks aftermarket.
I have NO clue why you have two disconnect switches except maybe the factory one is non-functional.
Equalizer WDH
Old 09-14-2019, 07:20 AM   #6
The second owner installed switch is connected to the box on the right. What is that box on the right?
An inverter?
tomkatb is offline   Reply With Quote
Old 09-14-2019, 09:24 AM   #7
Jeff
Jcf0527's Avatar
I believe the box on the right is the cover for the cable TV connection. At least thatís what the one in my Leprechaun is. Flip,it open and there should be a coax connection. Or maybe thatís where the solar hooks up?
Jeff & Peggy
2017 Coachmen Leprechaun 319MBS
Avid campers since 1999
Jcf0527 is offline   Reply With Quote
Old 09-14-2019, 10:02 AM   #8
Mr. Dan's Avatar
An inverter?
Looks like an inverter to me.
OP, can you post a pic showing that entire box?
SEARCH is your friend!
Nights Camped: '13 = 49/'14 = 74/'15 = 74/'16 = 85/'17 = 110/'18 =111/'19 = 86; booked = 0
Old 09-21-2019, 01:51 AM   #9
Little black box is the cable. I assume that switch is for the trailer? Other picture switch in battery compartment is for the batteries?
ID:	215448   Click image for larger version
battery, switch
