Old 06-18-2009, 10:11 AM   #1
Battery Tender
I've heard that some inverters can tend to overcharge batteries. Do any of you use the Battery Tender trickle charger to keep your batteries up to snuff in between outings?
Thanks!
Jim
AzJim625 is offline   Reply With Quote
Old 06-18-2009, 10:21 AM   #2
bikeman's Avatar
my owners manual says it will trickle charge the battery, it also says if you are going to use a charger to disconnect it from the trailer cause its bad for the convertor.
2000 Wildwood 30BHSS
2001 Suburban 2500
bikeman is offline   Reply With Quote
Old 06-18-2009, 11:07 AM   #3
CLASS "A" Senior Member
cfsoistman's Avatar
Thanks!
Jim
Personally I don't have the Battery Tender because my Xantrex Invertor has a 3 stage charger. I saw a TV show not too long ago where Gary Bunzer "RV Doctor" recommended the Battery Tender because of the trickle charge ability. It won't overcharge the battery. As for disconnecting from the trailer I don't recall if there was any mention of that. I believe I also saw it recommended on Two Guys Garage and My Classic Car on Speed Channel.
http://www.batterytender.com/
2007 Georgetown 370TS
aka - RAYNMKR
Driver: Charlie
Navigator: Sheri
Old 06-18-2009, 04:41 PM   #4
acadianbob's Avatar
Well I have a Voltminder, a Battery Tender, and a 3-Stage Converter. According to the Voltminder, the 3 stages of the converter put out 13.9, 13.6, and 13.2 Volts. These represent boost, saturation, and float. Supposedly the 13.2 float can be left on and not boil out your battery; and that may be true. But instead, when our trailer is parked for extended periods of time, I disconnect the battery and hook up a Battery Tender. I use the Battery Tender on the trailer and both of my tractors (extended sitting and intermittent use). The Battery Tender does an awesome job of maximizing charge without boiling out the battery and has anti-sulfation technology. Float does kick in on my 3-Stage converter as confirmed by the Voltminder. But I prefer to use the Battery Tender.
2018 F250 Lariat 6.2 4X4 w 4.30s, 2018 Wildcat 29RLX
2003 Yamaha FJR1300, Demco Premiere Slider
Red Green coffee mugs
Old 06-18-2009, 05:56 PM   #5
PJ73USAF's Avatar
I always use a Battery Tender on the coach and house batteries when not in use.I also use them on my motorcycles,I've found that this practice greatly extends the life of the batteries.The Battery Tender is a great product.
PJ73USAF is offline   Reply With Quote
Old 06-18-2009, 09:58 PM   #6
Thanks to all for the responses!
The real purpose was to keep the backup battery charged offline while being able to charge the main battery on the trailer.
I think I just missed a good deal on them. They were on sale online for about $46 and are now back up to about $65.
Oh well, I think I'll order one anyway. Sounds like a good investment.
Thank you all again.
Be prepared, I've got lots of questions coming your way.
Jim
battery
