Old 06-09-2015, 08:40 PM   #1
Battery Thief - Shocking!
I recently had my 12v battery stolen out of my 2012 Forest River Rockwood Freedom 1950 tent camper. The Thief just cut the wiring. I'm left with 4 wires and do not know exactly where they were connected. #1 is large white Ground and is directly connected at one end to the frame. #2 is the brake system orange/black power wire. #3 is a red wire that appears to go the the switch for the electric winch. #4 is a black wire that appears to go to the winch switch as well.
Where do this wires connect?
My "educated" & common sense answer is that the brake power wire goes to the positive terminal on the battery and the white ground wire goes directly to the the negative post. Is this correct? and do each of the the remaining wires goes as follows:
Red to positive black to negative.
CampingFool is offline   Reply With Quote
Old 06-11-2015, 11:31 AM   #2
I had my battery stolen also and the wires cut as well! It SUCKS!😁
I had to replace the cables because after cutting them they were to short. I went to auto store and got black and red cables. The black is ground to frame. The red has the bolt to connect wires to. The red wire goes to transfer (just follow the old one). I only had a red wire which went to positive. I am not sure about your black wire but I would follow it and find out what it is running. I assume it is positive but you know what assuming does😀.
I went on line and found a battery box lock. It is made of heavy medal and wraps around the box and you put a pad lock on top of it.
Good luck
Chuck
octo692 is offline   Reply With Quote
Old 06-11-2015, 11:38 AM   #3
Were these Thefts committed while you were Camping? Youroo!!
Old 06-11-2015, 11:54 AM   #4
Herk7769's Avatar
White may be ground!
Black may be HOT.
Do not assume otherwise.
If you are not SURE do NOT connect your battery.
Seek help if needed to meter each wire for voltage (using shore power) before connecting your battery.
Getting it wrong will cause more damage that won't be covered by your comprehensive insurance.
HAM CALLSIGN - KC3FFW
Old 06-11-2015, 11:58 AM   #5
TURBS's Avatar
Black should be hot!
TURBS
08 duramax tuned n modded
2011 32bhok Sabre
2015 camping "9 nights"
Old 06-11-2015, 02:41 PM   #6
My thief was in my driveway now I have cameras so I can at least see it being done! Ha Ha
Old 06-11-2015, 03:03 PM   #7
Charliec's Avatar
I got one of these to eliminate the theft problem.
B & D RV Battery Lock For RV travel trailers and popup campers.
Charlie C
2012 Ford F-150
2015 Rockwood 2504S
Charliec is offline   Reply With Quote
Old 06-11-2015, 08:36 PM   #8
HONDAMAN174's Avatar
X2 ^^^^
Just glad to get away
Old 06-12-2015, 06:42 AM   #9
Octo 692, thanks for the reply,I was hoping that it Did Not happen in a Campground! Youroo!!
Old 06-12-2015, 07:02 AM   #10
Thats nice.
Would a chain around the box and a padlock do the same?
2016 Flagstaff 23LB
howie70 is offline   Reply With Quote
battery
