08-31-2014, 12:53 AM
#21
Location: Alberta - East of the Rockies, West of the Rest
This is an excellent question.
I am not an expert on C/C's, but I do know that it is best to have a charger that can be programmed for the type and size of battery (or batteries) you have installed. AGM batteries can handle a higher recharge rate than flooded batteries but AGM's can not be equalized at a high voltage because they are sealed.
Here are links to websites with excellent information on RV Electrical.
Electrical Tutorial
RV Electrical
http://www.marxrv.com/12volt/12volt.htm
2018 RAM 5500 Laramie CC
Sold: Riverstone Legacy 38RE, 960 Watt Solar, 6x6 Volt AGM Battery Bank, Freedom SW 3012 Inv/Charger
Ordered: 2021....
08-31-2014, 11:11 AM
#22
Just found a good article on Trailer Life, not as technical though.
All about DC Power Conveerters in RVs
Ordered: 2021....
08-31-2014, 11:31 AM
#23
If the batt are new the first time they are charged, they well takemore water ! than normal
F-250 . stealth 3210 solar pannels, fantastic fans. and life line batteries
08-31-2014, 11:33 AM
#24
The RV Battery Charging Puzzle
If you have a large pot of joe, you should check out "The RV Battery Charging Puzzle". The beginning is a little slow, but further down he really cuts to the meat of it.
The RV Battery Charging Puzzle « HandyBob's Blog
Now we can all go back and talk about mods.
09-07-2014, 10:57 PM
#25
So I read the handy bob article. Thought about it. And now I think I need to replace my inverter, wiring, and batteries. Or I could just buy a separate charger and new batteries?
09-08-2014, 05:56 AM
#26
I installed 2 Interstate 6 v GC batteries on my TT with 123 watts of solar charging. In 2 seasons of use I have been checking the fluid level to make sure the cells are covered. I have never had the add water. Are others having the same experience? I would have thought the fluid level would have dropped somewhat.
09-08-2014, 06:32 AM
#27
My system uses water when they are discharged/charged heavily..but not much more than a few ounces for the pair of Trojans. In between trips, almost none, as in a few drops in each cell.
2000 Cherokee 29BH with 6V batteries, LED lights & 400 watts of solar power, flipped axles and raised. 2007 Tundra 5.7L DC-LB with lots of mods. C-co, 8/158th AVN Maint.
09-08-2014, 10:19 AM
#28
Happy owner SOB
Don't know if it's been mentioned but use only distilled water to top off wet cell batteries.
2015 F350 4X4 Crew Cab Lariat
Sunnybrook Titan 30FKS
09-15-2014, 05:00 PM
#29
2020 Forester 2851SLE
OK, really new RV'er here, picked up a 2015 Sunseeker 3010DS 2 weeks ago and was trying to check battery water levels and I can't figure out how to get the battery covers off to see inside. I see from a tag on the batteries that they are 27MDP (presume Exide) does anyone have any suggestions? Do I have to disconnect them first or ???
09-15-2014, 05:16 PM
#30
Any chance you can post a picture. Usually the covers (2) are rectangular and you can pry them up revealing three cells each, with a screw driver. Water (distilled) should be added until it reaches the bottom of the plastic fill holes.No, you do not have to disconnect. Just remember its acid, so treat it with respect.
09-15-2014, 06:00 PM
#31
Mine didn't come off easy.... No joke wear eye/face protection, way too easy to splash a little.
09-15-2014, 06:21 PM
#32
Also make sure they are not sealed. If so, prying a "cover" off will destroy the batt integrity.
Brenda and John
Master Blaster of the Navy
09-17-2014, 02:10 PM
#33
Thanks to all for input on this. The tops were hard to get off because of placement of cables and straps but thanks to one of those paint can openers with a hook on the bottom I was able to get the right leverage to pry them up. YEEHAW and the batteries were topped off.
11-23-2014, 09:31 PM
#34
And my batteries are dead now..... Won't hold a charge.
