Old 05-20-2015, 10:03 AM   #1
Battery Voltage
So I have 2 - 12 volt deep cycle marine batteries that are fairly new, bought them last year. I keep the trailer on the side of the house with the battery disconnect out and a battery charger on the batteries that fully charges them then goes to trickle mode. When I but a meter on the batteries (after charging) they read about 13.6v, but wage I connect the battery disconnect it drops to 12.6v.... Does that seem normal? I checked and there's nothing in the trailer except the fridge. Thanks
msteeler is offline   Reply With Quote
Old 05-20-2015, 10:14 AM   #2
Witch Doctor's Avatar
Sounds normal to me, you are reading a surface charge. Then it should drop to 12.7 or 12.6 that's full charge state. To test your charge you need to let it sit for 24 hrs and then see what your reading is. It still should be 12.6.
Rockwood #8289 WS 2012
F250 6.0 / Husky 16k
With 4 point leveling system
Witch Doctor is online now   Reply With Quote
Old 05-20-2015, 10:46 AM   #3
Thanks. I came across a chart showing 12.6 as a full charge. I guess this is what happens when the first 2 camping trips I have full hookups... I forget what voltage a battery should be when its time to dry camp
Old 05-20-2015, 11:09 AM   #4
Fully charged is 12.6v , each of the six cell's is 2.1v fully charged.
2014 Forester 3051s
2016 Nissan Pathfinder SL
2012 Sonic toad
wana65stang is offline   Reply With Quote
Old 05-20-2015, 11:34 AM   #5
1l243's Avatar
Normal when mine is plugged in it reads 13.7 when unplugged for a day it drops to 12.7.. I have four deep cycle 12 volt batteries...
Now that I finally added a battery cut off switch I can go for a very long time before having to plug in when in storage..
1l243 is offline   Reply With Quote
Old 05-29-2015, 10:00 PM   #6
A good and fully charged flooded lead acid so called 12 volt battery should read around 12.6 volts once stabilized and at rest subject to temperature. If hooked to a working quality Smart 3 Stage Charger, it would rise to around 14.4+ in Bulk Charge Mode, 13.6 or so in Absorption Charge, and finally settle in around 13.2 volts in the Float Charge mode, again subject to temperature and charger design parameters.
John T Retired Electrical Engineer
OldJohnT is offline   Reply With Quote
battery, voltage
