Old 05-25-2015, 09:15 AM   #1
Battery will not work
Hello, all i really need help with one of 2 things, either a link to the 2011 Shasta Revere 27bhs by Forest River I think that is it. need a link to the owners manual.
or
Here is our problem. we can not use a battery, yes all the fuzzes are good check again on the weekend, the trailer will work with Direct hook up to our Generator or power supply but nothing from the battery. took the battery out Friday full charge and nothing. we are so confused, was told by our dealer that there was a Triangle box with a button in the middle we have nothing like that.
Thank you all
trailerworries is offline   Reply With Quote
Old 05-25-2015, 09:42 AM   #2
fonzie's Avatar
Check underneath your trailer near tongue for a mini-breaker and press reset black button, hopefully that will be it. Also check your reversing fuses in your distribution panel to see if good, usually 40 amps (those will blow if battery is hooked up reversed)....
ID:	77988   Click image for larger version
Name:	breaker panel cover.jpg
ID:	77990   Click image for larger version
Fonzie
Old 05-25-2015, 01:24 PM   #3
Will look
Hello, Thank you Very much for your Pictures, The silver box you show on teh first one is a bit different but we will lookinto that For sure. and re-check teh fuzzes.
in the very last picture - Is that a little black Button? if so that would be easy to miss.
Thank you Again
battery
