Old 06-02-2011, 08:43 PM   #1
Battery Wiring Help for Dummies
I took my battery off my 2009 Rockwood 190XR for the winter and failed to draw a diagram of which wires goes where. I have 2 red wires, one black, one white and one thin green. Now I cannot raise my pop-up to pack for next weekend! Can anyone please help?
Thanks, Ty
tydo58 is offline   Reply With Quote
Old 06-02-2011, 09:07 PM   #2
The positive and negative posts should be different sizes (diameter). If the wires have the proper sized terminals, you should be able to figure it out that way. If the wiring is stock from the factory, you can also look at the wiring diagram in your documentation for additional guidance.
dlhoppe is offline   Reply With Quote
Old 06-02-2011, 09:53 PM   #3
Herk7769's Avatar
Pictures might help us figure this out. I also take pictures before I take anything apart since my memory is not that good either.
HAM CALLSIGN - KC3FFW
Old 06-05-2011, 09:51 PM   #4
I've posted a photo of the wires in the Community-Albums section. Sorry couldn't figure out how to attach it here. It appears that the thicker Red&Black wires are the pos/neg for the power winch...got that working.
Heres what I think in regards to the others:
The White (with black tape) is the ground as it is attached to the frame and this would go on the - terminal.
The thinner red with fuse is the + for the pigtail and should go on + terminal.
The green looks to be part of the breakaway so I would assume this would also go on the + terminal?
Do I pass? Thanks in advance, I appreciate the help!
Old 06-05-2011, 09:59 PM   #5
Sounds right to me.
~Andrew
99 F250 Super Cab Short Bed 7.3 Powerstroke
84 24' Yellowstone Camino (oldie)
http://rvpdi.com
Acableguy06 is offline   Reply With Quote
Old 06-05-2011, 10:01 PM   #6
sherdep's Avatar
Found your wiring
2011 Rockwood Mini Lite 2306 - Matt
2004 Dodge Ram 1500 Qaud Cab 4x4 with 35" tires and 3.92 gears, Dynatech Longtube Headers & Fabtech 6" lift + Superchips with shift Tuning
Nights Camped 2011 (37) - 2012 (16)-2013 (2) -2014 (5) -2015(0)
USMC 91 - 95 - F/A-18 Aviation Ordnance
sherdep is offline   Reply With Quote
Old 06-05-2011, 10:02 PM   #7
sherdep's Avatar
sounds right to me as well
the silver piece attached to the red wires is actually an isolator (lloks like it to me anyways) - not a fuse
Old 06-05-2011, 10:21 PM   #8
Thanks guys. Fuse is on the the other red wire in the black casing.
Old 06-05-2011, 10:24 PM   #9
sherdep's Avatar
I see it now - my eyes must have been focused on the silver and forgot about the black fuse holder
Old 06-06-2011, 06:45 AM   #10
Herk7769's Avatar
"Someone approached for help will never see the problem; however, anyone not approached for help will see the problem immediately."
Finagle's Laws
Here is what I think:
The silver box is a 40 amp current limiter and the red wire on it goes to your power converter.
The black fuse holder is power to a large current draw item (like a slide, landing gear, or power front jack).
The black wire is almost certainly Battery Ground and should go from the battery to the frame directly.
The white wire should also go directly to the frame ground as I believe it is the ground wire for whatever the black fuse holder powers. It is VERY unusually for grounds to all go to the negative terminal, but I see no reason why they could not. I think the black; the white; and the green; all go to the negative terminal.
MISSING from the photos. The battery.
My money is on:
There is a wire still missing from the photo. A red wire from the battery to the silver box terminal with no wire attached. Look around.
battery
