Old 11-04-2013, 02:31 PM   #11
wmtire's Avatar
Man, I hate to read these stories. It's just one of those live and learn things, and it can all be fixed.
Usually when this happens, you lose the converter, microwave, and television if equipped. Sometimes the microwave and tv will have an internal fuse that blows before real damage, but this is rare.
As other suggested, depending on the type of converter you have, this can be an opportunity to get a better one when replacing.
Great things about these forums here, is you can find the answers to fixing all that was damaged........as well as learning how to prevent if from happening again.
Good luck.
2011 Flagstaff 831 RLBSS
Iíve lost my scapegoat.
Old 11-04-2013, 02:38 PM   #12
I'm with ya...it's painful to read...and experience. So, where are the inverters on these? And how would a guy go about testing it? That and the microwave? I assume the micro and the inverter would have to be removed to be thoroughly tested??? Ours does not have a TV yet, so I feel fortunate about that, and the fridge, water heater, furnace, and water pump continued to run the rest of the day on battery power.
aldejoria is offline   Reply With Quote
Old 11-04-2013, 02:42 PM   #13
wmtire's Avatar
I know what you mean, but the correct terminology is converter. A converter converts 120 volt AC to 12 volt DC.
The converter should be near the bottom of where your breaker box is.
An inverter does the opposite function and inverts 12 volt DC (battery power) to 120 volt AC. Most trailers don't have an inverter, but coaches can.
This link may help explain all the confusing terminology as well as the functions of it all. Converters/inverters are explained about 3/4ths down in the link below.
http://www.rv-dreams.com/rv-electrical.html
Old 11-04-2013, 02:46 PM   #14
You are totally right....sorry about that...I guess I had that on my mind and kept typing it...lol...dang.
Old 11-04-2013, 02:59 PM   #15
TURBS's Avatar
Originally Posted by WaCamperATVfun View Post
Forest River
Wildwood LA, T27
2010
Travel Trailer
So some how we managed to plug into a 208v supply. I did some tests and found the 120v side to be fine other then the microwave getting fried (I think), I am getting around 2v on the load sides of the low voltage load sides. So I am guessing the converter/charger is shot? I tested all fuses on the front they are fine. It seems the battery is not getting charge any more also. Im guessing we are not the first to make this mistake so if anyone knows what usually pops first, perhaps a fuse I am not seeing or something. If you think it is the converter/charger might you know what I should get to replace it, I don't mind going with a upgrade either. THANK YOU FOR READING!
A progressive industries surge/voltage guard will prevent this in the future.
I recommend!
http://www.progressiveindustries.net/ems_hw30c.htm
Turbs
Old 11-04-2013, 03:02 PM   #16
That is a really nice looking unit...I guess that's the next step......thanks everyone, this all very good info. Now all I have to do is figure out how to disable that damn switch on the generator....
Old 11-04-2013, 03:08 PM   #17
Denver, CO
garbonz's Avatar
The way to check things is to use them. Microwave and TV is obvious, it no workee or it does. Fridge also, if the 12volt control board is ok, it will still work on Propane.
You should have 110 volts on both sides of the distribution center. I don't see why you would not and that has nothing to do with the converter. The converter you check by plugging the camper in and check voltage at the battery, which should be in the 13.2-13.7 range if the batteries are charged up. If it is at 12.8 or below, the converter is shot. Just go through your systems one by one.
Let us know what you find out, or if you have anymore???
2017 Fuse 23T
Old 11-04-2013, 03:13 PM   #18
I truly appreciate the help. I hope to look at it in the next couple of days...I'll post what I find......
Old 11-13-2013, 07:38 AM   #19
TURBS's Avatar
Any progress on this ?
Turbs
Old 11-13-2013, 10:07 AM   #20
Unfortunately, I've had to put off checking into it. It will probably bee the next week or two before I can really get into it. I'm anxious, though...and will post anything I find....good or bad, lol....on the forum. I appreciate all the info everyone volunteers, and I'd like to support that with my own info. I'll try and get some pics up as well.
