Old 04-04-2016, 10:49 PM   #21
camaraderie's Avatar
Originally Posted by Tom48 View Post
Keep them serviced well and maybe the insure they are balanced swop them around once in a while the same way you rotate your tires to assure even wear.
Good idea with that size bank. I'd get a hydrometer and compare specific gravity measurements before rotating...if you see them changing to lower in some of the bank...then do the swap of positions. Otherwise, just monitor occasionally when you check water levels.
________
Cam
2015 Georgetown 280DS
2014 Vespa LX150 2014 StellaAuto 125
camaraderie is offline   Reply With Quote
Old 04-05-2016, 04:51 AM   #22
Thanks for the help everyone.
Sent from a field
opie is offline   Reply With Quote
Old 04-05-2016, 02:08 PM   #23
I know amps are amps but in my experience using my 70 amp triple state charger/converter, it is quicker to get to 90% charge on individual battery banks than when both banks are charged together. After both hit 90%, I then allow both banks to trickle charge the rest.
Regardless, these were my observations when using generator and since I'm mostly solar for me its irrelevant.
Skyliner is offline   Reply With Quote
battery, battery disconnect
