Old 10-06-2014, 11:18 PM   #31
camaraderie's Avatar
If you are plugged into power...you should never see less than 13.2-13.4 or so. AFTER boondocking...when you plug back in...you should see at LEAST 14.4...which will gradually ramp down to around 13.8 after 2-3 hours... and then in the low 13's after 4-6 hours. It generally takes 4-6 hours on a decent charger to get your batts back to 100%. The ONLY time you should see anything below 13 is when you are boondocking.
________
Cam
2015 Georgetown 280DS
2014 Vespa LX150 2014 StellaAuto 125
camaraderie is offline   Reply With Quote
Old 10-07-2014, 06:25 AM   #32
Old Ram Guy
Avenger61's Avatar
Thanks! That helps ease my mind a lot. I was afraid I missed something in Dan-Nickie's diagram and everyone's tutoring efforts. Batteries are much more complicated than I ever imagined!! Thanks everyone!!!
Marty, Jenice and DD
Avenger61 is offline   Reply With Quote
