Old 04-16-2016, 09:20 PM   #1
volsfan162's Avatar
Boondocking no110 power even with generator running
We are new to our motor home so this is probably an operator error. Parked for the night somewhere, no elec hookup. Started generator and none of the electrical outlets or microwave are working. What are we doing wrong??
volsfan162 is offline   Reply With Quote
Old 04-16-2016, 09:27 PM   #2
Do you have a transfer switch? If not plug the shore power cable into the receptacle of Rv.
2017 Berkshire XL 40 BH
2015 Jeep Cherokee Latitude
Locomo14 is offline   Reply With Quote
Old 04-16-2016, 09:27 PM   #3
clr
Sounds like your transfer switch did not operate. The default position for the switch is AC Shore power. When you run the generator the transfer switch will normally switch the coach loads to the generator. Look up your transfer switch information and see if you can figure it out. Good Luck
clr is online now   Reply With Quote
Old 04-16-2016, 09:29 PM   #4
After checking that take cover off generator and check the circuit breaker there.
Old 04-16-2016, 09:37 PM   #5
volsfan162's Avatar
Thanks!!
Thanks! We plugged in and we got 110!!
generator, power
