Old 02-05-2016, 08:34 AM   #1
Brake Controller
I have a Prodigy 2 brake controller on my vehicle for my popup........everything works great. My son in the back seat often uses a small inverter for his laptop and such. The inverter plugs into a 12v socket, it has a low voltage alarm built in. Here is my question....if I'm in stop and go traffic......applying brakes at times......the low voltage alarm on the inverter will go off. Exactly how much voltage does the brake controller use?
Trevor43 is offline   Reply With Quote
Old 02-05-2016, 08:36 AM   #2
Who Dares, Wins
doc73's Avatar
What are you towing with? Wonder if because the engine is at idle the alternator is not putting out enough power. When's the last time the battery was checked?
Sent from my SAMSUNG-SM-G870A using Tapatalk
2015 ChevyHD D-Max
2018 Artic Wolf 315tbh8
doc73 is offline   Reply With Quote
Old 02-05-2016, 08:39 AM   #3
Battery is good all though I have not load tested it..........idle speed may not be enough output for everything involved.
Old 02-05-2016, 08:47 AM   #4
Who Dares, Wins
doc73's Avatar
That is what I meant, a load test. The battery may work "fine" at the surface but might be dead. You might not even know until that cold morning and the car does not start.
Not to assume, but my guess the inverter is just a 150 watter or something small? Cigarette plug typically cannot handle any large loads before melting occurs (usually fused at 5amps) .
Edit; did this just begin?
2015 ChevyHD D-Max
Old 02-05-2016, 08:49 AM   #5
Yeah......I was thinking outlet wiring may be on the light side
Old 02-05-2016, 08:58 AM   #6
DAISY BOYKIN's Avatar
Brake Controller
Your brake controller can at times draw up to 14-16 amps depending high you have it set. This high amp draw along with the inverter (HIGH DRAW device) And a battery that is getting age on it can trigger the alarm. The alarm is telling you the AC voltage output has dropped below safe operation voltage of AC to power the computer properly.
Sid, Lois & HRH MISSY Terrible 2s SHIH TZU
2011 ROCKWOOD 8285 WS
2014 F-250 KING RANCH PS/SD/6R140/BFT
DAYS CAMPED 2018 21 DAYS
DAISY BOYKIN is online now   Reply With Quote
Old 02-07-2016, 10:17 AM   #7
I would assume a single axle popup?
2 axle brakes approx 5a
Inverter 150w/12v = 12.5 a
I would have the electrical system checked on tow vehicle and also the battery on the popup check !
mfMcFroggierPod is offline   Reply With Quote
Old 02-07-2016, 10:25 AM   #8
Flybob's Avatar
Sometimes the after market brake controllers are connected to the Cig lighter 12V supply simply because it is easily accessible. The brakes can draw sufficient current (>10A) to cause a voltage drop on that line to trip a low voltage alarm. If you are concerned, run a new fused #12 wire to an open position on the fuse block.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 02-07-2016, 11:17 AM   #9
You don't mention what kind of vehicle you're using so I'll assume it doesn't have a voltage gauge. It would be helpful to know if the laptop's low voltage alarm is accurate and how much of a drop you're seeing. Next time you're towing I'd suggest connecting a voltmeter to an open power/cigarette outlet and checking voltage when braking. My suspicion would be that at idle you're alternator isn't generating as much power but I'd be surprised that the battery can't maintain the voltage level for at least short periods.
As Doc73 suggested have a load test done on that battery. I believe most AutoZone stores can do this for you in a matter of minutes.
Barry, MSgt, USAF, Ret. & Rose
2017 Ford F150 w/ 3.5 EB
2014 Coachmen Viking 17FQ
Colorful Colorado
La Plata View is offline   Reply With Quote
Old 02-10-2016, 08:06 AM   #10
The 600w power inverter will stop supplying 115vac to the laptop when in stop and go traffic......when it drops out the laptop will chirp as if it has been unplugged. Because this is plugged into the dc plug in the rear of the 2009 Santa Fe (for those requesting the vehicle make).....I'm sure it is a amp drop...........I also use the P2 controller with the Boost setting at 2.
brake control, controller, brakes
