Old 09-02-2014, 09:43 AM   #1
Breaker, Breaker OK?
I have a 20 amp fuse located under the trailer. I disconnect the battery when storing the TT. Quite often I find the fuse blown and have to crawl under and replace it. It is only blowing just after reinstalling the battery and everything works fine after that. I think I'm shorting it or the surge is poping the fuse. In any event I'd like to switch the fuse to a breaker whith the same amp rating, and move it to a more convienient location. Does anyone see a problem with this idea?
Bob
TV: Chrysler T&C
TT: Coachmen Clipper 17FQ
MV: West Wight Potter 15
CrifasiRF is offline   Reply With Quote
Old 09-02-2014, 09:45 AM   #2
Denver, CO
garbonz's Avatar
No problem with the idea, but I wonder what the heck could be pulling that much power upon reconnecting. If it is momentary, I am not sure how you would trace it but it doesn't seem normal to me.
2017 Fuse 23T
Old 09-02-2014, 09:55 AM   #3
chideock's Avatar
Why don't you pull the fuse just before installing the batteries and then put the fuse in once you have the batteries installed?
2016 Sunseeker 3010ds towing a 2013 Ford Explorer 3.5L AWD.
chideock is offline   Reply With Quote
Old 09-02-2014, 09:59 AM   #4
I was thinking about that, it seems unlikly so I'm assuming that I must be shorting it. Everything seems to be functioning fine otherwise. Once I put a switch in the line it should eliminate the fuse poping problem If I'm shorting it while reconnecting. I think I'll move it to a more convienient location anyway. I'll keep an eye on it after I put a switch in the line and before I change anything else.
TV: Chrysler T&C
Old 09-02-2014, 10:01 AM   #5
Thats a good Idea for trouble shooting. But still a pain because I have to crawl under the TT to do it.
TV: Chrysler T&C
breaker
