Old 01-22-2014, 04:51 PM   #1
Breaker/Fuse Panel designations
I have a 2012 Coachman Freelander 21 QB, Chevy Chassis. When it was built the factory didn't do a very good job of CLEARLY writing what the fuses and breakers are for. You literally cannot read some of the hand writing on my panel. I have 9 twelve volt fuses and 4 120v breakers. Can someone tell me they should read?
fatfender is offline   Reply With Quote
Old 01-27-2014, 09:21 PM   #2
Breakers are 30amp main, 20amp? Converter, microwave, tv/DVD, the easy way to figure it out is turn off all the breakers except the 30 amp main then turn them on one at a time and check the ac loads. The only tricky one is the converter because it charges the battery. It should be the second breaker down from the top
Trikkineon is offline   Reply With Quote
breaker, fuse
