Old 06-08-2016, 12:00 PM   #1
Breaker Location for rear stabilizers WC 28RKS
Have a 2011 Wildcat 28RKS and rear stabilizers just quit working. Until proven otherwise, I'm hoping it's just a fuse or breaker. Had a quick look and don't see anything in close proximity to the motor. Anyone with this trailer model that might know the location of the breaker? I can move them manually no problem so nothing seized up.
Awaiting a reply.
Thank you
Floyd & Carolyn
2012 F150 S/crew 4X4 6.2L 6Spd Tow Max Firestone airbags. 2011 28RKS Wildcat. Yamaha 3000iseb Gen.
2013 22 nights.2014 57 nights.2015 116 nights
2016. 96 nights 2017 72 nights.
Filterman is offline   Reply With Quote
Old 06-15-2016, 08:54 PM   #2
There are two 30 amp fuses that fuse the front and rear manual stablizer switches. Mine are located on the left side of the trailer on the inside of the frame about 30 inches in back of the battery disconnect. I have a 27' 2014 Wildcat Maxx. They are enclosed in a case with a flip top lid.
wwc1921 is offline   Reply With Quote
Old 06-30-2016, 02:42 PM   #3
Did some electrical trouble shooting today and I can get power with my test light all the way to where the wires enter the motor casing. Seems one wire is for extend and one is for retract, which must mean the motor is case grounded. Tried running a jumper wire from the motor housing to a good ground but still no go. I presume this means a new motor. Does anyone know of a good source of aftermarket motors for the Lippert levellers or am I stuck with the crazy pricing on the OE ones.
Thx
Floyd
Floyd & Carolyn
Old 06-30-2016, 02:59 PM   #4
Pickin' & Campin'
Have you tried holding the switch and lightly tapping around the motor case with a hammer?
Sometimes a brush inside the motor will stick and tapping on it will loosen it up.
Days Camped: '15=22 '16=46 '17=30 '18=4
breaker, cat, location, stabilizers
