Old 08-23-2012, 08:54 AM   #11
Great Horned Owl's Avatar
Originally Posted by vasnipe View Post
If you have a Harbor Freight store nearby they have a couple of circuit tracers
Circuit Breaker Detective
Or this cable tracker
Cable Tracker
Chris in Virginia
That Cable Tracker is the way to go. It puts a high frequency signal on the wire and then probe for the signal. Il allows you to follow the routing of a wire through the walls. Given the convoluted way some RVs are wired, this can be a very handy tool. It will work with 120 v circuits or 12 v circuits. By putting the signal on the shield, you can also use it on the coax in your tv inputs.
Joel
2011 Silverado 2500HD Duramax, 4x4, crew cab, long bed
Palomino Puma 253-FBS, 27' 5th wheel
1994 19' Class B on Chevy chassis
Great Horned Owl is offline   Reply With Quote
Old 08-23-2012, 03:50 PM   #12
Ok thanks guys I will try to find out where they go when I get time as it is real busy around here. Thanks again for the replies.
2004 Sierra 330RL 5th Wheel
2002 Silverado 2500 Duramax 4x4
States I have camped in
lonewolf is offline   Reply With Quote
breaker
