Old 08-11-2012, 05:14 PM   #1
Question Breaker Panel ?
I was looking at the panel today and noticed I have a 15amp breaker that has Gen written beside it. Does this mean it is for a generator or what? I don't have a generator so what else could it be?
I have a 2004 Sierra 5th Wheel with 30amp service just to cover what I have.
2004 Sierra 330RL 5th Wheel
2002 Silverado 2500 Duramax 4x4
States I have camped in
lonewolf is offline   Reply With Quote
Old 08-12-2012, 07:06 AM   #2
Darn I was hoping to get some kind of response about this. Because if it is not being used I could use it for some other circuit.
Old 08-12-2012, 07:13 AM   #3
Herk7769's Avatar
Might be specific to Sierra.
If that breaker is to feed (or be fed from) an on board generator (and you do not have that option) there won't be a wire connected to it. I would remove the cover and look.
If there is a wire, a trace would be in order to see where it goes. Is there a "home" for a generator in the Sierra? There might be a switch over relay setup in there that uses that breaker.
Lou & Freya the wonder dog
2019 Flagstaff 8529FL
Old 08-12-2012, 05:01 PM   #4
Well I looked and there are 2 black wires going to it. How would you do a trace to see where they go? I am new to all this.
Old 08-12-2012, 05:09 PM   #5
TURBS's Avatar
My sabre has same thing.
But no gennie .
I'm guessing it's labeled on all of them that way.
Old 08-12-2012, 06:41 PM   #6
If I could find out where the wires go I may be able to use it for something else.
Old 08-23-2012, 05:50 AM   #7
Can anyone tell me how to trace these wires as I have turned off the breaker but can't figure out what they go to?
Old 08-23-2012, 07:05 AM   #8
Herk7769's Avatar
You could try this.
Turn off ALL circuit breakers EXCEPT the generator one.
Use Amazon.com: Greenlee GT-16 Adjustable Non-Contact Voltage Detector: Home Improvement to find the wire path and where it goes.
Old 08-23-2012, 08:19 AM   #9
TURBS's Avatar
Www.powerprobe.com
Also makes a device to trace wires I believe.
Old 08-23-2012, 08:34 AM   #10
vasnipe's Avatar
If you have a Harbor Freight store nearby they have a couple of circuit tracers
Circuit Breaker Detective
Or this cable tracker
Cable Tracker
Chris in Virginia
2006 Sunseeker 3100SS/LTD
2008 Smart Passion Cabriolet TOAD
1986 Honda Helix (Original owner)
vasnipe is offline   Reply With Quote
Old 08-23-2012, 08:54 AM   #11
Great Horned Owl's Avatar
Cable Tracker
Chris in Virginia
That Cable Tracker is the way to go. It puts a high frequency signal on the wire and then probe for the signal. Il allows you to follow the routing of a wire through the walls. Given the convoluted way some RVs are wired, this can be a very handy tool. It will work with 120 v circuits or 12 v circuits. By putting the signal on the shield, you can also use it on the coax in your tv inputs.
Joel
2011 Silverado 2500HD Duramax, 4x4, crew cab, long bed
Palomino Puma 253-FBS, 27' 5th wheel
1994 19' Class B on Chevy chassis
Great Horned Owl is offline   Reply With Quote
Old 08-23-2012, 03:50 PM   #12
Ok thanks guys I will try to find out where they go when I get time as it is real busy around here. Thanks again for the replies.
breaker
