Old 08-11-2012, 05:14 PM   #1
Question Breaker Panel ?
I was looking at the panel today and noticed I have a 15amp breaker that has Gen written beside it. Does this mean it is for a generator or what? I don't have a generator so what else could it be?
I have a 2004 Sierra 5th Wheel with 30amp service just to cover what I have.
2004 Sierra 330RL 5th Wheel
2002 Silverado 2500 Duramax 4x4
States I have camped in
lonewolf is offline   Reply With Quote
Old 08-12-2012, 07:06 AM   #2
Darn I was hoping to get some kind of response about this. Because if it is not being used I could use it for some other circuit.
Old 08-12-2012, 07:13 AM   #3
Herk7769's Avatar
Might be specific to Sierra.
If that breaker is to feed (or be fed from) an on board generator (and you do not have that option) there won't be a wire connected to it. I would remove the cover and look.
If there is a wire, a trace would be in order to see where it goes. Is there a "home" for a generator in the Sierra? There might be a switch over relay setup in there that uses that breaker.
HAM CALLSIGN - KC3FFW
Old 08-12-2012, 05:01 PM   #4
Well I looked and there are 2 black wires going to it. How would you do a trace to see where they go? I am new to all this.
Old 08-12-2012, 05:09 PM   #5
TURBS's Avatar
My sabre has same thing.
But no gennie .
I'm guessing it's labeled on all of them that way.
Old 08-12-2012, 06:41 PM   #6
If I could find out where the wires go I may be able to use it for something else.
Old 08-23-2012, 05:50 AM   #7
Can anyone tell me how to trace these wires as I have turned off the breaker but can't figure out what they go to?
Old 08-23-2012, 07:05 AM   #8
Herk7769's Avatar
You could try this.
Turn off ALL circuit breakers EXCEPT the generator one.
Use Amazon.com: Greenlee GT-16 Adjustable Non-Contact Voltage Detector: Home Improvement to find the wire path and where it goes.
Old 08-23-2012, 08:19 AM   #9
TURBS's Avatar
Www.powerprobe.com
Also makes a device to trace wires I believe.
Old 08-23-2012, 08:34 AM   #10
vasnipe's Avatar
If you have a Harbor Freight store nearby they have a couple of circuit tracers
Circuit Breaker Detective
Or this cable tracker
Cable Tracker
Chris in Virginia
2006 Sunseeker 3100SS/LTD
2008 Smart Passion Cabriolet TOAD
1986 Honda Helix (Original owner)
vasnipe is offline   Reply With Quote
breaker
