Old 07-04-2012, 07:50 PM   #1
breaker problem
I have a 2012 wildwood 26bh travel trailer i can not use the a/c when the elc hot water heater.the mic trips the breaker even a hair dryer this is a new trailer help!!!!!! Eddieintx
eddieintx is offline   Reply With Quote
Old 07-04-2012, 08:43 PM   #2
sherdep's Avatar
I can run the A/C and hot water heater together but adding a Hair Dryer pops the breaker within a few minutes of use.
What wattage Hair Dryer are you using?
I can run the A/C and the Microwave without tripping it.
you only have a 30 amp circuit
the A/C alone draws between 12 to 15 amps
so when you add the Microwave, Hot Water Heater and dont forget the converter is charging the battery as well - doesnt leave much room for another appliance
2011 Rockwood Mini Lite 2306 - Matt
2004 Dodge Ram 1500 Qaud Cab 4x4 with 35" tires and 3.92 gears, Dynatech Longtube Headers & Fabtech 6" lift + Superchips with shift Tuning
Nights Camped 2011 (37) - 2012 (16)-2013 (2) -2014 (5) -2015(0)
USMC 91 - 95 - F/A-18 Aviation Ordnance
sherdep is offline   Reply With Quote
breaker
