Old 07-09-2012, 12:22 PM   #1
Bunk bed lights on a 23LB
Hi light are not working. I tried many things but no 12v is comming to wires in bunk bed lights.
Every other light are working fine so i started to check the wires junctions from others lights around with no luck.
Is it feeded by a single wire comming by the fuse box or by a wire comming from another light?
Where can i see the wiring diagram?
My trailer is a Flagstaff Micro-Lite 23LB 2010
Thanks!
Gerry
Gerry45 is offline   Reply With Quote
Old 07-09-2012, 12:27 PM   #2
TURBS's Avatar
Thanks!
Gerry
Is there a switch on the wall?
Does it have power?
There is no such wiring diagram in existence.
Old 07-09-2012, 09:13 PM   #3
Does it have power?
Each light (3) have a switch. There was no power but i found the problem.
It was a bad connection on the of the lower bunk bed (storage box).
All is working now.
Thanks!
23lb, bed
