07-14-2019, 06:23 AM
Retired
Burned out bulb - internal lighting fixture Rockwood 2109
Hi all,
The 2 watt LED bulb mounted in an internal light fixture of my Rockwood 2109 is just about dead. I've tried to unscrew it and did the push and turn maneuver without any luck. I unscrewed the small bezel at the base of the bulb and that didn't reveal any tips on how to remove it. Got any ideas that will help me avoid the possibility of a couple of bloody fingers ??
Thanks much !
07-14-2019, 06:38 AM
Following as my 21FBRS is the same rig with the same fixture.
Joe
Current: 2022 Keystone Cougar 26RBS
Past: 2020 Rockwood MiniLite 2205S
Past: 2018 Flagstaff MicroLite 21FBRS
Past: 2005 Flagstaff Classic 625D
TV: 2016 Ford F-150 3.5 EcoBoost
07-14-2019, 06:45 AM
Did you try just pulling on it?
Fonzie
07-14-2019, 06:57 AM
Retired
Thanks for the comment. I tried pulling on it but very lightly. Do you think a little more pressure is the solution ??
BTW, I am a novice blogger so i'll apologize now for any "blogging mishaps" !!
07-14-2019, 07:21 AM
I don't have that type of fixture, so can not advise you more. Hope someone with same will chime in.
Fonzie
07-14-2019, 01:00 PM
Burnt out bulb
These are on Ebay. Cheap. Replace entire fixture. Part number on fixture I think.
07-14-2019, 01:03 PM
On Ebay
07-14-2019, 02:05 PM
Looks like these would be the bulbs. So you would push and turn to remove.
https://www.amazon.com/Arcon-16788-R...24430318&psc=1
Fonzie
07-14-2019, 02:11 PM
Originally Posted by fonzie
Agree. Mine are these type. PS...Get the LED versions.
2016 RAM 3500 DRW 4x4 LB LoneStar, w/RDS 33Gal Aux tank, Timbrens, Andersen Ultimate2, SwiftHitch SH04
2018 Chaparral 360IBL w/TST507 TPMS, Lippert GC3 Autolevel, Furrion Backup Cam, Progressive HW50C
2006 RAM 3500 DRW LoneStar Edition
2011 Starcraft 392BHUw/Andersen No-Sway
07-14-2019, 03:31 PM
They take #1383 bulbs. Like some older automotive tail lights, push and turn. I always wear gloves always when changing a bulb. You can get incandescent or LED replacements for the #1383 style.
2018 Forest River Rockwood Roo
24WS
2019 Ford SD F-350 SRW Lariat
Tow & Gooseneck Prep
FX4 Off Road (4X4)
07-14-2019, 06:36 PM
To avoid ct fingers when the glass breaks, Wear Gloves...............
Ask me how I know!
2009 Chevy Silverado 2500HD CCSB LTZ Diesel, Fumoto Oil Drain Valve, Turbo Brake activated, 39 gal Aux Tank W/ Fuel Pump transfer, Air Lift Loadlifter 5000 air bags.
07-14-2019, 08:40 PM
SafetyCamper
Hi Tommy D. I had the exact same type of light go out in our 2016 Ultra V and this type of light (that I had) you could not change the bulb....we had to replace the entire light fixture. It was under warranty and I had CW change it out. This happened twice with different lights. These LED's should not go out in the life of "our" ownership. Especially something brand new! Make the company replace it! Good Luck and Safe Travels! JW
07-16-2019, 05:30 AM
Retired
Thanks to all
Hey all:
First, I'm a novice blogger so I hope this message goes where it is intended to go.
Thanks very much for the responses and for tracking down the info I need to get this fix completed.
I think Plan a is to "glove up" and give the twist and turn method one more shot. If that works i'll buy new bulbs. With the cost of replacement fixtures so reasonable Plan B int such a a bad alternative.
Hope you all are having a good camping summer !
07-16-2019, 07:56 AM
Might have to push it in slightly, then turn. Like automotive tail lights. They make LED's in all sorts or bases now to replace those hot, power hungry incandescent bulbs.
Even my "all LED" rig still had some incandescent bulbs inside and outside that I have replaced.
24WS
FX4 Off Road (4X4)
