Old 07-08-2014, 12:38 PM   #21
How about the converter? That was the problem when ours wouldn't charge the battery
OKI Marine is offline   Reply With Quote
Old 07-08-2014, 01:13 PM   #22
GalsofEscape's Avatar
My converter is working. I am thinking (hoping) more of the inline 30 amp battery fuse holder as I noticed this weekend that now the battery is not supplying power to the fridge when I disconnect from shorepower. I had switched the fridge from ac to dc just before unhooking the shore power when we were getting ready to leave our campsite and the fridge worked on dc through the converter, though once disconnected from the shore power, the fridge went dark. And it is a fully charged battery (had it on a battery tender while we camped). The fridge did not come back when I plugged into the tow vehicle either but when I wiggled that fuse, the fridge came on but did not stay on. The fuse is good (new), so I am thinking the holder is bad. And I am hoping it is something that simple.
HTT: "EscapeII" 2016 Shamrock 23WS (current)
PUP: "Escape" 2010 Rockwood HW 277 (gone)
TV: "Gill" 2022 RAM 2500
Just us gals (me, Sis and our daughters)
We spend alot of money to go sit in the woods
GalsofEscape is offline   Reply With Quote
Old 07-08-2014, 02:50 PM   #23
Herk7769's Avatar
Originally Posted by Timex View Post
Hey Herk, when you were helping me a few weeks back you had me look for the current limiter. I found it then(about 3 feet down the line from the battery) but it had no button on the side to push in. Is this an automatic resettable component or does if have to be replaced when defective? I believe mine is working properly but wanted to know for future reference.
Without the manual reset button; it should reset automatically.
If not it is broken and should be replaced.
Lou & Freya the wonder dog
2019 Flagstaff 8529FL
Old 07-08-2014, 02:51 PM   #24
Herk7769's Avatar
Certainly sounds like the socket to me as well.
Old 07-10-2014, 03:42 PM   #25
You cannot run your refridgerator in DC mode without something continually recharging the battery. In DC mode, the fridge will run the battery down to nothing in a matter of hours - I have seen it happen to friends too many times. Typical draw for a PUP or A-frame fridge on DC is about 6 amps or more.
To keep my battery as good as I can make it when dry camping, I turn the refridgerator off before I unhook the tow vehicle power. When shore power is available, I run the fridge on AC. Without shore power, the fridge runs on propane. The DC is only used when towing the camper.
On most small camper fridges (larger fridges don't usually have DC mode), the DC mode is the weakest - provides the least cooling - of the 3 modes. Propane usually does best, with AC second best.
just my experiences
Fred W
A122 towed by Hyundai Entourage
Old 07-10-2014, 04:22 PM   #26
I am well aware of what drains the battery and I was not running the fridge on dc while camping and I never said I was dry camping. In fact, post #1 stated I always camp with electric hookup. I had the battery DISCONNECTED while camping and had it on a battery tender so I was not using any battery power.
Old 07-13-2014, 03:46 PM   #27
update
it was the 30 amp fuse holder/socket!! and an easy fix that did not require the dealer. thanks everyone.
battery, camper, charging
