Old 02-23-2016, 08:51 AM   #11
banda's Avatar
Originally Posted by Still Kickin View Post
Yes, fine steel wool. Buff it back to the clean copper color. Good to go. If your good, you can use 1600 grit sand paper, keeping in mind that your not trying to remove metal (copper), but just shine it back to a clean apperance.
I've been trying to find a way to get the steel wood and/or sandpaper into all the nooks and crannies of both the male and female sides of the connectors. My tarnish is really stubborn. I just thought of something. I wonder if the wife's emery boards would work for this. Anyone ever tried that?
banda is offline   Reply With Quote
Old 02-23-2016, 08:58 AM   #12
There are "burnishing tools" made in many sizes & configurations to clean electrical connectors. They are like very fine emery boards or files, just very fine as not damage the metal. May have to get from an electronics store, but work very well; used them for years to clean electrical contacts in relays, contactors, etc.
Papa GLS is offline   Reply With Quote
Old 02-23-2016, 09:04 AM   #13
hammer55's Avatar
my dremel has a few small files a polishing tips
Mark & Annie
2014 COACHMEN PURSUIT 27 KB
Modesto, Central California
hammer55 is offline   Reply With Quote
Old 02-23-2016, 09:11 AM   #14
Some also have very small wire brushes; great idea.
Old 02-23-2016, 10:01 AM   #15
Hey STILL. Yeah that's why I was hoping for a solvent or very runny Brasso type of cleaner that I could use like a flux brush to remove the tarnish without damaging the blades/pins/contacts. Thanks for the suggestion. Will try that too!
Lifetimecamper is offline   Reply With Quote
Old 02-23-2016, 12:58 PM   #16
Mix up a paste of Baking soda and water....Will neutralize the corrosion....Real good on battery terminals.....J
Jim in Halifax is offline   Reply With Quote
Old 02-23-2016, 05:00 PM   #17
TandSH's Avatar
As for dielectric grease BTW, your most widely available and economic source is something called "petroleum jelly". AKA "Vaseline" or any generic equivalent! No need to pay for some 'brand name' product.
Ted
2017.5 Cedar Creek 34RL2
2018 F-350 Lariat CC SRW PSD 4x4
USMC Fighter Pilot (Ret)
TandSH is offline   Reply With Quote
Old 02-23-2016, 05:18 PM   #18
I don't know where I read it, but for the truck side I put steel wool wrapped around a drill bit and go to town. It polishes up the terminals removing any tarnish real nice and quick!
Kf4mnc is offline   Reply With Quote
Old 02-23-2016, 05:32 PM   #19
Ted
Dielectric grease is silicone based and will not react with plastics or seals.
Petroleum jelly, as the name implies, is petroleum based and may react with plastic connectors or seals.
2016 Jayco Eagle 330RSTS = "Madame Maxime"
Maxxis M8008 E rated Tires and 16" Wheel Upgrade
Dual A/C, 14K Equalizer WD hitch with SC
King Bed with Java Interior, (2X) Yamaha EF2000isV2
2012 Ram 4500, 6.7L Cummins TD, MegaCab = "Hagrid"
360 degree Virtual Tour
Fairenatic is offline   Reply With Quote
Old 02-23-2016, 05:44 PM   #20
Banda,Yes the cheap throw away emery boards fit and do a good job cleaning the Female connectors of cords! Youroo!!
camper
