Old 02-22-2016, 11:01 AM   #1
Camper plug terminal oxidation removal
Hi everyone. Just curious if anyone has or knows of, a product or way to clean up the tarnished or oxidized terminals in the female ends of a camper's power cord or extension cord.
Thanks!
Lifetimecamper is offline   Reply With Quote
Old 02-22-2016, 11:09 AM   #2
CRC Terminal Cleaner..........for maintenance pipe clear and dielectric grease
Trevor43 is offline   Reply With Quote
Old 02-22-2016, 02:22 PM   #3
Thanks Trevor. I'll check it out for sure.
Old 02-22-2016, 02:26 PM   #4
That's supposed to be Pipe Cleaner
Old 02-22-2016, 04:09 PM   #5
......and here I was looking at Drano Thanks for the correction
Old 02-22-2016, 06:14 PM   #6
davel1971's Avatar
tool kit to clean and test connector Robot Check
David & Lynn
Old 02-22-2016, 06:21 PM   #7
davel1971's Avatar
that is an Amazon link, have no clue why it says "Robot check". Never seen that before.
David & Lynn
Old 02-23-2016, 07:35 AM   #8
Thanks Dave. Yeah, that is a strange way to link but it led to a few options for cleaning up terminals
Old 02-23-2016, 08:25 AM   #9
+1 for dielectric grease on all your electrical connections on the RV and TV
2016 Jayco Eagle 330RSTS = "Madame Maxime"
Maxxis M8008 E rated Tires and 16" Wheel Upgrade
Dual A/C, 14K Equalizer WD hitch with SC
King Bed with Java Interior, (2X) Yamaha EF2000isV2
2012 Ram 4500, 6.7L Cummins TD, MegaCab = "Hagrid"
360 degree Virtual Tour
Fairenatic is offline   Reply With Quote
Old 02-23-2016, 08:28 AM   #10
Thanks!
Yes, fine steel wool. Buff it back to the clean copper color. Good to go. If your good, you can use 1600 grit sand paper, keeping in mind that your not trying to remove metal (copper), but just shine it back to a clean apperance.
camper
