02-22-2016, 12:01 PM
Camper plug terminal oxidation removal
Hi everyone. Just curious if anyone has or knows of, a product or way to clean up the tarnished or oxidized terminals in the female ends of a camper's power cord or extension cord.
Thanks!
02-22-2016, 12:09 PM
CRC Terminal Cleaner..........for maintenance pipe clear and dielectric grease
02-22-2016, 03:22 PM
Thanks Trevor. I'll check it out for sure.
02-22-2016, 03:26 PM
That's supposed to be Pipe Cleaner
02-22-2016, 05:09 PM
......and here I was looking at Drano Thanks for the correction
02-22-2016, 07:14 PM
tool kit to clean and test connector Robot Check
02-22-2016, 07:21 PM
Originally Posted by davel1971
that is an Amazon link, have no clue why it says "Robot check". Never seen that before.
02-23-2016, 08:35 AM
Thanks Dave. Yeah, that is a strange way to link but it led to a few options for cleaning up terminals
02-23-2016, 09:25 AM
+1 for dielectric grease on all your electrical connections on the RV and TV
2016 Jayco Eagle 330RSTS = " Madame Maxime"
Maxxis M8008 E rated Tires and 16" Wheel Upgrade
Dual A/C, 14K Equalizer WD hitch with SC
King Bed with Java Interior, (2X) Yamaha EF2000isV2
2012 Ram 4500, 6.7L Cummins TD, MegaCab = " Hagrid"
360 degree Virtual Tour
02-23-2016, 09:28 AM
Thanks!
Yes, fine steel wool. Buff it back to the clean copper color. Good to go. If your good, you can use 1600 grit sand paper, keeping in mind that your not trying to remove metal (copper), but just shine it back to a clean apperance.
02-23-2016, 09:51 AM
I've been trying to find a way to get the steel wood and/or sandpaper into all the nooks and crannies of both the male and female sides of the connectors. My tarnish is really stubborn. I just thought of something. I wonder if the wife's emery boards would work for this. Anyone ever tried that?
02-23-2016, 09:58 AM
There are "burnishing tools" made in many sizes & configurations to clean electrical connectors. They are like very fine emery boards or files, just very fine as not damage the metal. May have to get from an electronics store, but work very well; used them for years to clean electrical contacts in relays, contactors, etc.
02-23-2016, 10:04 AM
my dremel has a few small files a polishing tips
Mark & Annie
2014 COACHMEN PURSUIT 27 KB
Modesto, Central California
02-23-2016, 10:11 AM
Some also have very small wire brushes; great idea.
02-23-2016, 11:01 AM
Hey STILL. Yeah that's why I was hoping for a solvent or very runny Brasso type of cleaner that I could use like a flux brush to remove the tarnish without damaging the blades/pins/contacts. Thanks for the suggestion. Will try that too!
02-23-2016, 01:58 PM
Mix up a paste of Baking soda and water....Will neutralize the corrosion....Real good on battery terminals.....J
02-23-2016, 06:00 PM
As for dielectric grease BTW, your most widely available and economic source is something called "petroleum jelly". AKA "Vaseline" or any generic equivalent! No need to pay for some 'brand name' product.
Ted
2017.5 Cedar Creek 34RL2
2018 F-350 Lariat CC SRW PSD 4x4
USMC Fighter Pilot (Ret)
02-23-2016, 06:18 PM
I don't know where I read it, but for the truck side I put steel wool wrapped around a drill bit and go to town. It polishes up the terminals removing any tarnish real nice and quick!
02-23-2016, 06:32 PM
Ted
Dielectric grease is silicone based and will not react with plastics or seals.
Petroleum jelly, as the name implies, is petroleum based and may react with plastic connectors or seals.
02-23-2016, 06:44 PM
Banda,Yes the cheap throw away emery boards fit and do a good job cleaning the Female connectors of cords! Youroo!!
